Brake dust revisited...
Old Apr 21, 2008 | 07:22 AM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Which pad produces more brake dust:
OEM
Mintex Reds
I have a brand-new set of Mintex Reds, but if they dust just as much as OEM in a single week, I'm going to put them up for sale & buy something different.
I don't do ANY tracking or autox, just LOTS of spirited driving.
Current OEM pads/rotors have 21K miles on 'em...I'm open for suggestions!
Old Apr 21, 2008 | 09:52 AM
that7guy's Avatar
that7guy
The OEM's will produce more dust.
Old Apr 21, 2008 | 12:18 PM
RaceFace's Avatar
RaceFace
I just ordered ceramic pads from Carbotech this morning for my Clubman. I am over the dust already!
Old Apr 21, 2008 | 05:46 PM
wellzy's Avatar
wellzy
if you dont like dust get the carbotech 1521 (bob cat) they make almost none. my wife has them on her r50 it has been a week and all i did to clean them was to hose them then dry with a towel also they will not cut rotors up like other pads will and they stop better then oem
Old Apr 21, 2008 | 05:55 PM
Sin MINI's Avatar
Sin MINI
How do the Bobcat and other aftermarket pads affect the warranty? Concerned about rotor wear, etc...
Old Apr 21, 2008 | 07:52 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The Bobcats better for your rotors then the OEM pads. The issue is our OEM rotors are designed to be replaced every 50K. You may get more miles out of them, but not hard miles. If you have less then 35K on OEM rotors, replacing OEM pads with Bobcats will help you get more then 50K out of the rotors. If you are up over 35K on the OEM rotors you'll save money in the long run to replace the rotors at the same time you change the pads. You might want to think about our brake package on any MINI over 50K. Yes the all the Carbotech pads work with the brake senors.
Old Apr 21, 2008 | 08:19 PM
pure13's Avatar
pure13
Try EBC Green Stuff, I've been using EBC pads for more than 6yrs on all my cars. Great initiate bite and much lower dust than stock, also the dust washes off easy.
Old Apr 21, 2008 | 08:33 PM
wrxmini's Avatar
wrxmini
OEM
Mintex Reds
hey erika,look no further,the oem pads on my car were driving me nuts wilwoodbp-10,great stopping power,no noise,no dust= $70 a set
Old Apr 21, 2008 | 08:39 PM
wrxmini's Avatar
wrxmini
btw,i also tried the ebc pads and thought they were c#*p,use a good brake fluid,ate blue for example and the bp 10s and your good for the canyons
Old Apr 27, 2008 | 03:52 PM
1FSTMINI's Avatar
1FSTMINI
reg brake fluid is enough for everyday driving and the occasionally mountain run.
You would only need a high temp brake fluid if you autoX the car every weekend.
BernieCoop
Sep 10, 2021 03:15 AM
Sep 10, 2015 10:52 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
squawSkiBum
Sep 2, 2015 09:56 PM
