Suspension Klunk Klunk
Old Apr 16, 2008 | 08:55 PM
EDM's Avatar
EDM
Klunk Klunk
Ah yes, the dreaded klunking.
I recently installed a new Koni/HSport Setup on my MINIs and now about 400 mile later im starting to get a klunking sound. It feels like its mostly the drivers front, but may be passenger side as well, but i cant exactly hear it as well.
The noise sounds kind of like a hollow klunking and mainly is heard when the car is at lower speeds and going over small bumps. Sounds like theres a "shake" somewhere because i hit something and it gives off a couple quick thuds.
Any ideas? Thanks in advance.
Old Apr 16, 2008 | 09:17 PM
checkmate2006's Avatar
checkmate2006
make sure the top nut is torqued down all the way because i had the same deal and it came down to turning the speed up on my air wrench to get it on fast with out the piston shaft spinning.
Old Apr 16, 2008 | 09:31 PM
EDM's Avatar
EDM
Im gonna try that out. to make for certain. ill be back on tomarrow to let you know how it goes.
*fingers crossed*
Old Apr 16, 2008 | 09:32 PM
xnotfunkylex's Avatar
xnotfunkylex
^ +1
I actually had the nuts come off of the rears and had to get new ones. Made a similar sound over bumps.
Old Apr 17, 2008 | 05:08 AM
EDM's Avatar
EDM
Danke gentlemen, im gonna give this a try today
Old Apr 17, 2008 | 11:57 AM
Chilipeppa03's Avatar
Chilipeppa03
Danm sorry to hear that David!
Old Apr 17, 2008 | 01:20 PM
Damo's Avatar
Damo
I'm getting something that sounds ike this, but it was after I had the Alta PSRS fitted
It wasn't the top nuts tried that, but not had chance to try anything else.
Old Apr 17, 2008 | 01:21 PM
checkmate2006
how many miles are on your car? when you did the install of the PSRS did you make sure you torque all the bolts correctly?
Old Apr 17, 2008 | 01:23 PM
Damo's Avatar
Damo
I've got 50k on mine
Old Apr 17, 2008 | 03:41 PM
EDM's Avatar
EDM
well i went to the hobby shop and tightened the bolts real snug and really havent heard anything since, so im gonna say thats that!
Unless it recurs, then ill be back!
Old Apr 17, 2008 | 06:02 PM
checkmate2006
Good to Hear and if you got them really good I don't think it will be back unless the nuts some how come loose.
Old Apr 17, 2008 | 07:40 PM
cpayne's Avatar
cpayne
I had this intially for the 1st week.
-1) Sprayed some WD-40 down the top hole down through the top camber plates
-2) Made sure the springs were not rubbing on the inner wheel wheel w/ my -2 Deg Camber...they were...sprayed with liquid lithum grease until could pound the wheel wells in more at a later date (still havent done it)
-3) Of course if the top nut is loose..then ya..that would make noise.
Very quiet for over 2 months now
Old Apr 18, 2008 | 06:29 AM
checkmate2006
The other possibilitys clunk is either your factory strut bearing could be shot or if you have aftermarket camber plates the strut bearing or pillow ball bearings could be shot also. Also if your MINI has high miles you front control arm bushings are more then like likey totally shot.
Old Apr 18, 2008 | 06:32 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Also make sure that your swaybar endlinks have been fully tightened after you re-installed the springs. It's easy to not tighten them enough and then you get that hollow clunk noise you're talking about.
Old Apr 20, 2008 | 05:26 PM
SHRTSTAK's Avatar
SHRTSTAK
Could this also happen in the rear? The top nut not being tightened all the way down?
Old Apr 20, 2008 | 07:51 PM
UKSUV's Avatar
UKSUV
EDM.....man.....wtf are you doing to your poor car...
Old Apr 20, 2008 | 09:11 PM
EDM's Avatar
EDM
hehe, i nicked the klunking and moved on to finally fix the motor mount.
...i get bored...
Old Apr 20, 2008 | 09:17 PM
xnotfunkylex
YES. I had both nuts come completely off my rears. I think I must have drove at least 2000 miles like that. Don't think it did any damage. But the struts and springs would drop every time I hit a bump. If you jack up the rear and pull/push on the struts they should wiggle if anything is loose. You could also just pull them out and tighten them up in mot much more time.
Old Apr 21, 2008 | 10:21 PM
SHRTSTAK's Avatar
SHRTSTAK
So is there anything else that would cause a clunking sound in the rear when hitting a bump? For instance, my Alta sway bar needing some grease? My Ireland control arms needing some grease? Have stock rear end links on a lowered (rather extremely lowered) car?
Supertractor3
Oct 19, 2014 07:01 PM
CDMINI
R55 :: Clubman Talk (2008+)
40
Apr 17, 2011 06:12 AM
Burno
Aug 5, 2010 08:16 AM
