R50/53 Theoretical question about testing the speed sensor, is it possible too plug new....
Old Apr 13, 2008 | 09:04 AM
jeffrimerman's Avatar
jeffrimerman
Is it possible to plug the new one in and then grounding to the car to see if the dsc light goes out? This way one could quickly see which one is bad so one doesn't have to take the wheel off and swap the whole thing out. It's probably a dumb question and I imagine the wheels have to spin to give a signal that would tell the computer there is nothing wrong anymore, then the light would go out.
Old Apr 13, 2008 | 09:21 AM
Jhud's Avatar
Jhud
the fault needs to be cleared and the wheel needs to spin in order to generate a signal to be referenced to other wheels by the dsc
Old Apr 13, 2008 | 09:23 AM
jeffrimerman
Will the fault clear when the new sensor is installed and the signal is generated? Or does it need to be cleared by resetting the system somehow? Thanks Jhud
Old Apr 13, 2008 | 09:25 AM
Jhud's Avatar
Jhud
you can try a battery reset ( disconnect negative for 10 minutes ) but im not 100% sure this will resolve the issue
Old Apr 13, 2008 | 10:44 AM
vdubdoug's Avatar
vdubdoug
the fault will cleer automatically if all the sensors are ok, Mine did.
Old Apr 13, 2008 | 04:00 PM
jeffrimerman
Ok kewl, i will change it soon. Hopefully it is the first one I try. If not then I will swap it to the other side. I would imagine only one should go bad at a time, so I'm gonna change the front drivers side, if that doesn't clear it, then I will swap it to the passenger side. If that doesn't do it then I will swap the rr to the rl and see what happens. Someone mentioned that the speedometer runs off the rr so since my speedometer is working fine that one is good for sure.
Old Apr 13, 2008 | 06:52 PM
jeffrimerman
OK the drivers side front didnt do anything, so now I'm gonna swap it to the passenger's side. I wonder how long it would take for the warning light to go out. I would think right away. How long did yours take vdubdoug?
Old Apr 13, 2008 | 07:34 PM
vdubdoug's Avatar
vdubdoug
mine went away after i strted the car and drove it aout a 1/4 miles. then i proceded to drive agressively to try to see what would happen. it has not come back on since and that was over about 2 months ago.
Old Apr 13, 2008 | 07:55 PM
jeffrimerman
I drove around the block,so that should be over 1/4 mile. And the light is still on with both sides being swapped back and forth. I will swap the rear ones tomorrow to see. Hopefully that is the problem. If not, then some have mentioned the stearing column sensor, but that wouldn't cause the tire pressure sensor light to come on also. What about inside the wheel where the magnet of the speed sensor measures? Could that go bad?
Kimolaoha
Jul 5, 2023 01:04 PM
Bublik
Feb 18, 2023 11:09 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
MES11
Aug 8, 2015 10:21 AM
