R50/53 DSC, and tire pressure sense light on...
Old Mar 23, 2008 | 01:36 PM
jeffrimerman's Avatar
jeffrimerman
I tried resetting with the button under the brake, but it didn't do anything.
I pulled off the front tires to check the wiring because the engine was changed and the lights came on after the engine was swapped. I didn't see that the wires were disconnected. They looked fine.
I checked the DSC fuses.
I had previously disconnect the negative battery terminal to see if that resets it, but it didn't.
The pressure is fine, which shouldn't matter if I'm just trying to reset the tire sensor. If tire pressure is off then it would just trip it after, but not prevent it from reseting.
So the question is: What could cause both light to remain on, that will also disable the tire pressure reset button? Would it me something with the DSC system that causes both, or would it be something with the tire pressure sensor system that causes both lights to come on?
Old Mar 23, 2008 | 06:24 PM
Ancient Mariner's Avatar
Ancient Mariner
Uumm, let me be the first: year? model?
Old Mar 23, 2008 | 06:38 PM
glnr13's Avatar
glnr13
bad speed sensor
Old Mar 23, 2008 | 10:32 PM
jeffrimerman
It is an 03 non-s with manual tranny. So could it be a big coincidence that it just happen to go bad when they changed the motor? Or maybe my friend was wrong and the light was on, hmmm. Is there a way to check the speed sensors and eliminate which ones are good? So if the speed sensor is bad then the switch to reset the tire pressure sense will be disabled also? I wonder if I can disconnect the battery to reset the ecu so I can see if that temporarily lets me reset the tire pressure light.
Old Mar 23, 2008 | 10:55 PM
glnr13's Avatar
glnr13
the DSC and tire pressure both use the wheels speed sensors.
you can go to an autozone or to a dealer and have them run the OBD scanner to find out exactly which sensor is acting up provided that it's only the sensor.
could also be the steering angle sensor... but then again that wouldnt affect the tire pressure monitor
hope it's not a bad harness
Old Mar 24, 2008 | 04:21 AM
DaveTinNY's Avatar
DaveTinNY
Mine turn on intermittently too... When they come on, I shut the car off and then restart. That usually clears it. Do a search on this subject matter. It's out there already.
2005 MCS Manual Trans
Old Mar 25, 2008 | 10:33 AM
jeffrimerman
Ok thanx, I will go to autozone to see what codes pop up. I imagine the obd plugs under the dash like most cars. It just seemed odd that the lights werent on before then after the engine swap, they are on. Before the engine swap the airbag light was on, now that light is off. I hope there isn't some mystery problem hehe. thanx again.
Old Mar 25, 2008 | 12:37 PM
Ancient Mariner
Go get a scan anyway. Codes are stored for some time, and it may still be in there even without the light on.
-skip-
Old Mar 25, 2008 | 02:39 PM
Suzann's Avatar
Suzann
I had this happen and it was an alignment issue..
Old Mar 25, 2008 | 02:49 PM
jeffrimerman
hmmmm
Wow, alignment issue. Did your car pull hard to a side? Mine goes straight just fine. So your had both lights on, tire pressure and dsc? But you reset switch should have still worked to reset the tire pressure or did it also stop that?
Old Mar 25, 2008 | 03:18 PM
AKIndiMini's Avatar
AKIndiMini
I have the same problem, except the ABS light comes on as well. It happens randomly (normally in damp or cold weather), and my OTC Genisys scan tool (in generic OBDII mode...I haven't picked up the euro car software yet...) won't pick up the ABS/DSC/TPM codes.
These systems are on separate modules than the EMS2000 (engine management module). So unfortunately, you need a scan tool capable of retrieving ABS/DSC/TPM codes from their respective modules. The scanners used at the autozones I've been to are simply generic OBDII scanners, so they probably won't pick up the codes. :(
I wish I could narrow it down without having to throw parts at it (wheel sensors, steering wheel angle sensors, etc), but I just can't afford the euro software for my scan tool at this time. :(
Old Mar 25, 2008 | 03:20 PM
jeffrimerman
yeah, that's what i was thinking too.
Old Mar 25, 2008 | 04:05 PM
jeffrimerman
Yup, went to autozone and the OBD tool showed no codes. So I need one that works with mini. I will check ebay and see what they have.
Old Mar 25, 2008 | 05:41 PM
jeffrimerman
the question is, where can i buy a speed sensor, and how can i change it myself.
I searched but didn't see a place to buy it, and didn't see any posts on how to change it myself.
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
