Cooper (non S) Modifications specific to the MINI Cooper (R50).
Photos of bolt protrusion w/M7 STB
Old Feb 23, 2008 | 01:50 PM
turboexempt's Avatar
turboexempt
Does anyone have photos of the bolts from the M7 STB creating the "nipples" on the hood?
I have the STB arriving Monday because I need the reinforcement for mushrooming (ie to prevent mushrooming before it starts) and figured I may as well go with the full STB since it wasn't much more. I still haven't decided if I will install the whole thing but seeing pictures of the bolt protrusions will help me make up my mind depending on how bad they are.
Old Feb 23, 2008 | 09:28 PM
AutoXCooper.com's Avatar
AutoXCooper.com
I'll take some pics of my bonnet Sunday and post them below.
Old Feb 24, 2008 | 12:33 AM
turboexempt
Awesome! This forum is great.
Old Feb 24, 2008 | 09:09 AM
AutoXCooper.com
OK, here are two pics, it's hard to see them. It's in bubble warp for storage. If you tilt the screen you can see them. When I still had the OEM on my MINI most people never noticed them. However mine is red and I bet the AB will show up more. I have been told that you can get lower profile bolts for the brace. I would also remove the under bonnet padding. I know a few have done it without any issues of heat damage to paint, but that is still a risk.
Old Feb 24, 2008 | 05:14 PM
turboexempt
Thanks for the pictures. Is there any noise difference in the cabin without the lining? So it's definetly just the bolt causing the bumps? And any ideas on where to get the low profile bolts?
Old Feb 24, 2008 | 08:16 PM
xnotfunkylex's Avatar
xnotfunkylex
The padding on the bonnet is not to prevent heat damage to the paint, but rather to help suppress a fire in the event that it happens.
Old Feb 25, 2008 | 11:25 AM
GOTCURVES's Avatar
GOTCURVES
I have an 05' MC with the M7 STB installed. I have no clearence issues with the brace mounting bolts. My issue is it raised the rear of the bonnet (nearest windshield) about 1/4" it's noticable if you look for it. I've had it installed for about 4 months now and no noises. I still have the bonnet liner in place (I don't want to remove it) and I believe that is what is raising my bonnet up. My brace bolts don't come near the bonnet (I'm not sure why) unlike alot of others owners do. I would install both (plates and brace) follow the install instructions (especialy soaking the liner with water and close the bonnet and let sit over night part) and see how things turn out. BTW if you have any mushrooming (I thought I had none) the reinforcement plates will not be lying flat when you place them on the towers (they will wobble). It took over 2 hours (with a 2lbs hammer and a piece of 2x4 stud) to get the towers flat again, but I'm glad I did. The fit was perfect and no wobble no matter where you put pressure on the plate. Hope this info helps.
Old Feb 25, 2008 | 11:46 AM
turboexempt
That helps very much. Can't wait to get home tonight to see how the STB fitment is on my R50.
jcb-memphis
Sep 16, 2015 05:45 PM
papawhiskey
Sep 14, 2015 05:47 PM
David.R53
Sep 13, 2015 03:44 PM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
