R50/53 PCV valve rubber elbow.
Old Jul 17, 2003 | 06:44 PM
RN3403's Avatar
RN3403
Has anyone else had the PCV valve(part load breather) rubber elbow go bad on them? It seems like the tubing they used for the elbow has been broken down buy the synthetic oil vapor that runs through this tube,causing it to collapse at RPM's above 2000rpm. If not,check this elbow and look for an oily residue and It should be fairly rigid to overcome the vacuum in the tube. Anyway, I just thought I would run it by everyone.
Old Jul 17, 2003 | 08:39 PM
orbhot's Avatar
orbhot
Where is it?
Old Jul 18, 2003 | 05:38 AM
artguy's Avatar
artguy
Oh yeah! This sucker went soft and started producing this horrible wheezing sound from under the bonnet. It was collapsing and narrowng so it sounded like a cheezy party horn when you let off the gas. My wife thought I was nuts when I mentioned it, but I had her step on the gas pedal while I was buried under the hood. And I found it!
The same oil vapor that caused this elbow to go soft, also made my supercharger rubber seal on the RIGHT side (facing the engine bay) go soft and slide around on the metal of the supercharger producing a really poor seal. The dealer cleaned it, the metal and all surrounding parts - still sliding around! They finally had to pull one off another car and replace it. No more wiggle - AND my MINI had a performance increase like you wouldn't believe.
Makes me wonder how long the thing was slopping around!? It's like getting a new MINI all over again! So the moral of the story - get that elbow replaced and while their rooting around have them check the supercharger seal too!
Old Jul 18, 2003 | 07:57 AM
RN3403's Avatar
RN3403
It's in front of the "M" of the MINI on the top of your engine.(Cooper S)
Old Jul 18, 2003 | 08:02 AM
MGCMAN's Avatar
MGCMAN
Wait a minute!
Why the only thing that makes wheezing/farty sounds and is in front of the M on my MINI's engine is.........Me??!! (Doh)
Homer Simpson
Old Jan 17, 2004 | 11:08 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The PCV valve and rubber elbow (goes soft) is a VERY common problem- please do check that your hose is hard or firm-if not have it replaced along with the PCV valve.
See this thread too-
https://www.northamericanmotoring.co...mp;topic=19418
_________________
Send a PM to minihune Mele Kalikimaka & Hau'oli Makahiki Hou!
elverado
Jan 18, 2022 02:51 AM
R3411y
Sep 11, 2015 03:38 PM
Sep 11, 2015 11:09 AM
kjd186
Sep 9, 2015 10:02 AM
ShadyCoop
Sep 8, 2015 04:50 PM
