Show me your Spacers!
Old Jan 30, 2008 | 01:53 PM
AstroBlackS's Avatar
AstroBlackS
OK. I finally decided on summer wheels & tires, and they now sit in the garage, awaiting the nicer weather.
After seeing a few Minis in the past with spacers, I have almost made the decision to get some. I'd like to see what everyone is running in terms of spacers, and see how they affect the look of the Mini.
So lets see them!
Old Jan 30, 2008 | 02:06 PM
MisterDangerPants's Avatar
MisterDangerPants
I ran 15mm H&R spacers with my S-Lites. I really liked the way they looked and had no issues. If I can find the photos, I'll post them post haste.
Old Jan 30, 2008 | 02:25 PM
roofaS's Avatar
roofaS
When I get the chance, will post pics of my 16mm Eibach's that are pushing my wheels way out of the arches - I hate it but have no choice because of the BBK
Old Jan 30, 2008 | 02:57 PM
AstroBlackS
sounds awesome! I Can't wait to see pics!
Old Jan 30, 2008 | 03:04 PM
MisterDangerPants
here's a photo I found when I was researching spacers. they were running H&R 10mm spacers:
Old Jan 30, 2008 | 03:17 PM
mbcoops's Avatar
mbcoops
H&R 5mm (40 offset wheels) - might do 10mm for this track season:
mb
Old Jan 30, 2008 | 03:44 PM
Berthil's Avatar
Berthil
Lowerd with Bilstein PSS9, 12mm spacers and Tarox big brakes (another 3mm offset), 1.5 degree negative camber.
The R95 have 4mm higher ET (more inward) than the S-Lites.
Old Jan 30, 2008 | 03:47 PM
glnr13's Avatar
glnr13
tangent... what lug conversions are you guys using?
Old Jan 30, 2008 | 04:29 PM
minimusprime's Avatar
minimusprime
h&r 5mm spacers in the front only, et37 oz ul's, and tsw stud kit.
Old Jan 30, 2008 | 04:36 PM
tazio's Avatar
tazio
10mm, a.k.a. The Spacer of Death
Old Jan 30, 2008 | 05:03 PM
AstroBlackS
These pics are looking good! I love the way it looks when the wheels are pushed out flush or more with the outer fender.
Old Jan 30, 2008 | 05:13 PM
UKCoopeR's Avatar
UKCoopeR
Old Jan 30, 2008 | 05:17 PM
tazio's Avatar
tazio
Originally Posted by UKCoopeR
10mm is the depth of the Mini hubs, which leaves nothing for... hubcentricity. 8mm and thinner stilll leave the wheel center something to hang on to, and 12mm and thicker will have hub extenders.
Old Jan 30, 2008 | 05:19 PM
AstroBlackS
I didn't know that... interesting.
Old Jan 30, 2008 | 05:21 PM
minipete07's Avatar
minipete07
So lets see them!
17X7.5'' +45offset RIMS, 215/45-17 TIRES with H&R 5mm spacers
Old Jan 30, 2008 | 05:22 PM
minipete07's Avatar
minipete07
Old Jan 30, 2008 | 05:24 PM
MisterDangerPants
here you go...
here's my old MC with S-Lites and 15mm H&R spacers:
Old Jan 30, 2008 | 05:28 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally 15x7 et40 with 5mm spacers all around to make it et35. Longer lugs from Gorilla
Just simply low offset wheels (basically the same aesthetic as adding spacers to wheels to achieve low offsets)
And a funny little animation to show what a difference wide wheels and low offsets makes. From a 5.5" wheel with an offset in the high 40s to an 8.5" wheel with an offset less than 10
Old Jan 30, 2008 | 05:41 PM
UKCoopeR's Avatar
UKCoopeR
oh i getz it know, thanks for the info
Old Jan 31, 2008 | 02:03 PM
AstroBlackS
sweet!
I've been thinking about the Madness 8mm Spacers & their Stud Kit
Old Jan 31, 2008 | 02:28 PM
agranger's Avatar
agranger
My track tires... 16" Rota Slipstreams with 12mm spacers on the front to fit over the Wilwoods and 5mm on the back. They look a little small, but it's all about performance when on the track.
Old Jan 31, 2008 | 06:35 PM
jhiggs26's Avatar
jhiggs26
What BBK are you running? I'm looking to find larger rotors and calipers that will fit my 17" by 7" et37mm OZ Uls and my stock 15" MINI winter wheels.
Jeremy
Old Jan 31, 2008 | 09:14 PM
agranger's Avatar
agranger
I'm running the 12.2" Wilwoods on the front only.
Check the TSW brake kit as well... they designed it to fit under some 16" wheels, I think, and the rotor is massively thick to help disperse heat and resist fade.
Oh yeah... I'm running studs from Turner Motorsport w/ the Muteki lug nuts from TSW.
Old Jan 31, 2008 | 09:39 PM
AstroBlackS
Anyone know hat size lugs/lug conversion size I'd need if running 8mm spacers?
Old Feb 1, 2008 | 05:48 AM
minimusprime
Ummm not quite sure exactly the size but the tsw stud kit i am using would fit that easily... just make sure you rtfm and install using the correct tq values.
