Runflat Tire Blues
Old Jan 28, 2008 | 07:52 AM
Mgbracer80's Avatar
Mgbracer80
Runflat Tire Blues
I have recently noticed that my rear passenger tire is no longer holding air and it looks like it needs replacing. Can I put a non run-flat tire on it and if so what are some tires you guys would recommend? And will a non run-flat effect performance? Right now it has a Pirelli 205/45r17 84v
Old Jan 28, 2008 | 07:55 AM
jay80424's Avatar
jay80424
Did you check it for a nail? That's the first thing I would do. It just may need a repair.
Old Jan 28, 2008 | 08:00 AM
jakay11's Avatar
jakay11
and if its not a nail, valve stems are also problem areas...
I would not mix tire types or brands... also depends on wear as well.
(I am currently running non-runflats)
Old Jan 28, 2008 | 08:01 AM
eager2own's Avatar
eager2own
In my experience a non-RF will effect performance -- but for the better.
However, you do not want to replace one tire. At the very least, you want both fronts to match and both rears to also match -- and preferably all your tires to match. So, as suggested, look to see if it's repairable first.
Old Jan 28, 2008 | 08:06 AM
Mgbracer80's Avatar
Mgbracer80
Everwhere I checked said they don't repair Run flats as if they were afraid.
Old Jan 28, 2008 | 08:13 AM
Gromit801's Avatar
Gromit801
The only real difference between a regular tire, and runflats, are the sidewalls. Runflat sidewalls are incredibly stiff, to allow them to be used for awhile, when you lose air pressure.
If the damage is to the sidewall, then it shouldn't be repaired no matter what kind of tire you have.
You can get tire repair kits at the better auto parts stores. You might be able to do it yourself.
If you just have a nail or a bad valve stem, I haven't found a tire shop yet that won't fix that. Keep looking.
Never mix tread patterns by using different tires on your car. Your handling will go away.
Old Jan 28, 2008 | 11:19 AM
sequence's Avatar
sequence
when I still had my Runcraps on (Dunlop 9000s) I took a nail and Discount Tire repaired it OK (I purchased the warranties the first day I had my car). However, there are certain brands' runcraps that they wouldnt (or couldnt) fix for whatever reason.
Old Jan 28, 2008 | 11:24 AM
Speedwing's Avatar
Speedwing
Run flats require a much more expensive tire machine. Keep calling around until you find a shop with the correct machine and they can probably repair it for you.
Old Jan 28, 2008 | 01:23 PM
dwdyer's Avatar
dwdyer
The word I got from a Discount Tire guy is that some manufacturers prohibit it, others don't. I got two Dunlop runflats plugged there.
I've heard many sing the praises of Dynaplug for DIY plugging, but I haven't tried it myself.
Old Jan 29, 2008 | 09:10 AM
Mgbracer80's Avatar
Mgbracer80
Thanks for all the help. I just went with 4 non runflat bfg's. Needless to say that I have 3 good runflats for sale now and if you think you can fix the fourth you can have it for free
Thanks again!!!
Troy
Old Jan 30, 2008 | 11:16 AM
Alex@tirerack's Avatar
Alex@tirerack
Many times the ability to repair a runflat has to due with how it was damaged, and if it was run without airpressure. No pressure will wear the tire beyond repairing.
Alex
Old Feb 5, 2008 | 06:36 AM
Bender07's Avatar
Bender07
Me too
I also have the right rear tire leaking as well. I took it to the Goodyear shop and they said it was not repairable and that I had to purchase a new tire at $400.00.
OUCH
Well, I went to eBay and found a used tire, exact size and brand with 90% life left for less than $100.00 but Goodyear said they wont install used tires.
What is up with that? Now I am looking for a shop to install the tire.
Old Feb 5, 2008 | 08:52 AM
PenelopeG3's Avatar
PenelopeG3
find another shop. they are just looking to lighten your wallet
Old Feb 5, 2008 | 05:41 PM
JohnJohn's Avatar
JohnJohn
<total newbie>
I have an 06 MCS with 17" Sport Package rims. I can replace all 4 tires with non-run flats? If I do this will Mini Roadside assistance still help me with a flat? ie (pick me up and drive me and the tire to a tire shop?)
Kimolaoha
Dec 5, 2020 09:32 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
Mini'mon
Aug 16, 2015 12:47 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
