Oil Smoke at Start Up
Old Jan 21, 2008 | 12:12 AM
CHI-TOWN TOM's Avatar
CHI-TOWN TOM
My late build MCS with 5000 miles has just started (within the last 1000 miles or so) to smoke immediately after a cold start. It is positively oil and the amount of smoke is greater after not being started for a few days. The car runs fine and the smoke clears quickly. Anyone experiencing the same. Thanks in advance.
Old Jan 21, 2008 | 12:51 AM
user 7082082's Avatar
user 7082082
Can you describe where the smoke is coming out from please and how you know its oil ?
Old Jan 21, 2008 | 01:18 AM
CHI-TOWN TOM
Smoke comes out of tailpipe. It is heavy, bluish in color, and takes several seconds to disipate. It is oil.
Old Jan 21, 2008 | 09:26 AM
Minidrivr's Avatar
Minidrivr
Some how oil is burning. It's either going by rings or coming in the through the intake. Have you checked the oil level recently? Make sure it's not over full.
Old Jan 21, 2008 | 05:11 PM
CHI-TOWN TOM
Oil level is just below full mark, not overfilled. Only smokes after it sits overnight, immedietely after starting. Seems oil is getting into the combustion chamber when engine is cool. Valve guides? I will be monitoring oil consumption very closely now.
Old Jan 21, 2008 | 05:41 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
have you changed your oil at all?
I switched synthetic blends on one the the WRX's I had, and oil started getting past the oil seal in the turbo. I switched back to the other brand and the smoke went away.
Old Jan 22, 2008 | 10:15 AM
giantjoe's Avatar
giantjoe
Did you obey your break in procedure? Not going over 4500rpm, varying speed etc.?
Read
Old Jan 22, 2008 | 02:16 PM
herbie hind's Avatar
herbie hind
this is common with a valve guide seal issue . if the car sat for an extended period like a year or something ; the seals could crack maybe . but if it's used often then i'd say a seal or more has prematurely failed .
Old Jan 22, 2008 | 04:04 PM
Li'l Red's Rider's Avatar
Li'l Red's Rider
+1
Old Jan 23, 2008 | 09:07 PM
CHI-TOWN TOM
Followed break in procedure prescreibed in OM, limited RPMs to below 4000. Changed oil and filter once at 350 miles using Mini Castrol and Mini filter. Car is my daily driver so it is used 6 to 7 days a week. Just returned from a 450 (highway) mile trip so I will check oil level to see if there was noticable consumption during the trip. Thanks to all that replied!
TREX
Nov 2, 2019 07:31 PM
Gil-galad
Eastern Iowa MINIs
17
Sep 12, 2015 07:13 AM
wind715
Aug 11, 2015 07:56 AM
Lt. Dan
Aug 10, 2015 08:23 AM
