Bonnet Is Askew!
Old Dec 10, 2007 | 03:29 PM
Scoopmama's Avatar
Scoopmama
Bonnet Is Askew!
Hi! I have an 07 MCS that was production week 31. On the passenger side, there is a gap of about 1 inch between the body and the bonnet. On the driver's side, there is no gap AT ALL, and I'm starting to see paint damage. My dealership is going to look at it this week, and I do have pictures that show it to a lesser degree that I took before I picked up the car.
Has anyone else had this problem? I'm assuming/hoping it's an easy fix!
Thanks!
Old Dec 10, 2007 | 04:00 PM
daffodildeb's Avatar
daffodildeb
Definitely sounds like a dealer fix, including the paint. I haven't had the problem. How long was it at the VDC?
Old Dec 10, 2007 | 07:56 PM
Scoopmama's Avatar
Scoopmama
It was only there for about 4 days. I didn't have any stripes or anything put on.
Old Dec 10, 2007 | 10:37 PM
TWON's Avatar
TWON
I have and still have this problem. My dealer acknowledges it is an issue that needs to be fixed on my mini. They have tried as much as they can to get it straight with no success. They just opened a "body shop" within their lot and are planning to have them give it a shot to get it fixed. They do not sound hopeful at all and think the entire bonnet will need to be replaced as it is the suspected problem. Your case sounds more extreme then mine as I do not have any contact points that are causing paint damage.
Sorry I couldn't make it sound more hopeful. Good luck with yours.
Old Dec 10, 2007 | 11:06 PM
Scoopmama's Avatar
Scoopmama
Thanks for the info. Actually I'm hopeful since now I know I'm not the only one out there! I appreciate it!
Hope you get yours fixed or replaced. Maybe it's a PW/Calif issue?????
Old Dec 11, 2007 | 06:21 AM
Nimcosi's Avatar
Nimcosi
You might want to try yourself and/or point your dealer towards this idea.
I had a slight gap on the left and the left side of bonnet did not appear to be latched as securely as the right. The above corrected my issue.
Old Dec 11, 2007 | 09:10 AM
TWON's Avatar
TWON
I also found that thread back when I noticed the problem, my has been adjusted as much as possible and is still askew. But thanks for pointing it out again, definitely worth a try Scoopmama!
Old Dec 11, 2007 | 06:13 PM
Scoopmama's Avatar
Scoopmama
Thank you! I printed out this thread as well as the one you linked to in you post. Will bring with me to the dealership tomorrow!
Appreciate all the help!
Moya45
Oct 17, 2015 07:54 AM
jennster
Sep 28, 2015 06:19 PM
rustof
11
Sep 25, 2015 10:35 AM
Jolio
Factory JCW Talk (2009+)
Sep 17, 2015 09:23 PM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
