5-lug conversion availablilty?
Old Dec 3, 2007 | 01:06 PM
ggv's Avatar
ggv
hello all
what would be involved in switching my '03 MCS to a 5-bolt wheel pattern? I am assuming that I would need to source some undrilled rotors and have them custom drilled for a 5-lug pattern, but what else would be required? Or is there already such a thing available?
This would be so that I could run some wheels that are only available in 5-bolt, in case anyone is wondering.
As well, what would be the proper rim width & offset/backspacing specs for 16" and 17" gen 1 MCS rims?
any info appreciated
thanks
greg v.
Old Dec 3, 2007 | 01:20 PM
kyriian's Avatar
kyriian
its not that simple, namely, the bolts go into the wheel hub, not the brake rotors, so you need a whole new wheel hub that somehow fits the mini, which no one makes
only way currently is with a hub adapter, it is like a spacer that converts the 4x100 pattern to 5x whatever
so far the consensus is that because minis are very offset sensitive, especially with lowering, that it is not a common procedure to go down. There is a gent who did a 4x100 to 5x130 bolt pattern and put porsche turbo twists on, it brings the offset somewhere down to 30, which is a big no no for lowered cars
our only choice really is porsche offsets, anything else would stick out too much, unless you have a wide body kit to go with the wider wheels and the lower offset
what wheels do you have in mind... BMW wheels for example will never fit a mini because they typically have low offset, and with the hub adaptor adding more space between your hub and your wheels, your wheels'd completely out of the car!
Old Dec 3, 2007 | 01:23 PM
txwerks's Avatar
txwerks
The hub is drilled for 4 lugs, too - so, you'd have to either:
1. Convert from the 4-lug hub to a 5 lug pattern with a custom adapter and get some custom rotors
2. Have someone make you a custom hub (with the correct splines for the axles) with the right 5 lug pattern and get some custom rotors
It's possible - but I'd think it wouldn't be cheap. Also, you'd have to start watching offset closely. IMHO, it's not worth the effort...
Old Dec 3, 2007 | 01:29 PM
hemiheaded18's Avatar
hemiheaded18
https://www.northamericanmotoring.co...Porsche+wheels
But what a look!
Old Dec 3, 2007 | 01:50 PM
ggv's Avatar
ggv
hey guys
thanks for the prompt responses; as you can tell, I'm just getting into the Mini thing, having bought my '03 only a few months ago. I didn't realize that Minis had the lugs in the hubs, not just the rotors, so I think converting to a 5-bolt pattern just went down the drain.
I had a fleeting interest of running some American Racing AR500's, which are basically a billet Magnum 500, to kind of pay homage to the original Mini Clubmans that came with the similarly styled ROStyles.
Anyways, thanks again.
cheers
greg v.
Old Dec 3, 2007 | 01:59 PM
hemiheaded18
Originally Posted by ggv
a billet Magnum 500.
Oh, man, old school. I wonder how Keystone Klassics would look on a MINI. Add some air shocks and a set of blow out speakers blaring Aerosmith's Dream On and its 1978 all over again.
Old Dec 3, 2007 | 02:33 PM
ggv's Avatar
ggv
I was with you up until the Aerosmith part.....I'd probably sub in some Maiden instead
At any rate, here's a rough comp of what I think it would look like, and I like it:
cheers
greg v.
Old Dec 3, 2007 | 05:34 PM
hemiheaded18
That is very surprisingly pretty good looking. I mean, damn good. Oh, and if there's no Aerosmith on, I'll go ahead about 10 years and put on Runaway by Bon Jovi.
Old Dec 3, 2007 | 05:45 PM
ggv's Avatar
ggv
thanks, at least that means I'm not the only crazy one. I think that some Torq Thrusts would also look great, but again there's the 5-lug issues to deal with, and I just don't know if I trust wheel spacer/adapters enough to use them, although I'm sure if the proper set is used correctly they are fine. As well, I have the suspicion that these style of wheels may only be suitable for rwd vehicles, but who knows.
And I'll compromise and settle for Wanted Dead or Alive, but that means I'll have to find & buy an NOS black leather Parasuco rocker jacket...ebay maybe?
cheers
greg v.
Old Dec 3, 2007 | 06:07 PM
gnatster's Avatar
gnatster
Personally I'd lean more toward The Band or Grateful Dead and slap some Gotti's or BBS on there.
or
Old Dec 3, 2007 | 07:18 PM
UKCoopeR's Avatar
UKCoopeR
those are some seriously HOT wheels
Old Dec 3, 2007 | 07:48 PM
TurboMini's Avatar
TurboMini
cheers
greg v.
These wheels are pretty hot and are pretty much replicas of the old Cooper S Sport Pack rims but available 16" or 17" instead of 12"
ASA JH6
Old Dec 3, 2007 | 08:02 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I like your style (music and wheels)
Though HTN offers the second wheel style in 4x100 so that makes it easier
(pic is 5 lug....but they come in 4 )
Old Dec 3, 2007 | 08:34 PM
PGT's Avatar
PGT
my buddy has those gotti's on his guard's red 944, but in silver. oxidized to hell. I keep asking him to send them to me so I can polish them for him. his reply? 'then I'll have to paint the car' :eh:
Old Dec 4, 2007 | 06:41 AM
toddtce's Avatar
toddtce
Yikes. Very un BBK friendly stuff.
Old Dec 4, 2007 | 07:54 AM
ggv's Avatar
ggv
found this thread on another forum with all our favorite wheels from yesteryear:
http://www.japanesenostalgiccar.com/...opic.php?t=605
enjoy!
greg v.
Old May 16, 2018 | 11:15 AM
Cincy_jro's Avatar
Cincy_jro
I guess I'll bring this one back to life... anyone had a chance to compare hubs from R56 and E82? the 128i has a 5 lug hub and should have gotten some of its design from the MINI platform I think. Just wondering if the hub mounting bolts would match up on centers. If so it would make converting easy and finding replacement rotors easy down the line....
Old May 16, 2018 | 12:00 PM
gumbedamit's Avatar
gumbedamit
http://www.42draftdesigns.com/vw-aud...l-adapter-set/
I have some 5-Lug 17in 3 Piece BBS's that I'm restoring that I got from a guy here on NAM. I've not purchased these adapter yet, but he has. Below is a link to his conversion:
https://www.northamericanmotoring.co...dest-look.html
Old May 16, 2018 | 12:40 PM
Cincy_jro's Avatar
Cincy_jro
I've seen these conversions before but I don't like that it spaces out the wheels so much. Drilling the stock units seems to be a solution but makes doing a brake job a PITA because you have to get your new rotors drilled every time.
A full hub assembly replacement seems like a great option if another BMW uses a similar bolt pattern for the hub mounting. I realize being RWD may be a problem with the BMW swap but just trying to think out loud and see if anyone else has given this a thought or attempted it...
Old May 16, 2018 | 01:31 PM
gumbedamit's Avatar
gumbedamit
I assume that since you are looking for a 5-lug conversion, you will be putting larger thicker tires/rims on, would you not need to put spacers on anyway, in this case 18mm?
With the stock 4-lugs, going with a wider rim/tires, would you not also need to use a spacer?
Old May 17, 2018 | 05:44 AM
Cincy_jro's Avatar
Cincy_jro
If that were the case yes, but I'm just looking at it from a bigger wheel selection stand point. Not necessarily to go wider or lower offset. I like the tucked look so keeping the offset close to stock would be preferred but have found a better choice of wheels with 5 lug.
Old May 19, 2018 | 10:38 PM
OCR's Avatar
OCR
Whats the difficulty with swapping in later (2011/2014 later) 5 lug hubs (axles ?) "
I assume a spindle change (front and rear) may be required, is this a possibility ?
Mike
Old Sep 2, 2019 | 04:02 PM
wascobi's Avatar
wascobi
no replies years later. looking into this as well. im not sure spending hours on real oem will provide answers. if it was easy as a hub n rotor swap, wow.
NYMADMINI
Dec 14, 2016 02:33 PM
Oct 1, 2015 12:13 PM
Sep 30, 2015 12:08 PM
Sep 29, 2015 12:11 PM
