R56 Speedometer: MPH to KM/H Switchable?
Old Nov 23, 2007 | 03:03 PM
Stefx's Avatar
Stefx
Hi
For you American Mini owners, does the 2008 model allow the driver to switch between mph and km/h on the speedometer?
Also, I assume the US Mini Cooper does not have Daytime Running Lights? Please confirm.
Many thanks
Old Nov 23, 2007 | 03:30 PM
lacning74's Avatar
lacning74
You can change the settings of the on-board computer to display metric units. Also, you can activate daytime running lights, which turns on all the lights, headlights, foglights, and taillights full-strength. It maybe annoying to others, but I guess that's the point.
Old Nov 23, 2007 | 03:42 PM
Stefx's Avatar
Stefx
thanks.
That makes it very easy to import in Canada then.
Old Nov 23, 2007 | 05:52 PM
lacning74's Avatar
lacning74
Hmmm. Importing?
If you are used to km/h, you would be stuck with the USA center analog speedometer faceplate only listing mph numbers. It does not even have km/h in small lettering.
While the electronic OBC will display mph, it is not the default display and would require you selecting it everytime you start the car.
If it does bother you and you're brave enough, you could probably swap the speedometer faceplate or maybe use white-out and a Sharpie marker.
Here's a partial view of the speedometer.
Old Nov 23, 2007 | 07:25 PM
Stefx's Avatar
Stefx
thanks for clarifying it.
That means I'll have to have the speedometer faceplate changed then. It's a requirement of the Canadian "DOT"... new cars can be imported but have to be modified to get daytime running lights and km/h speedometers.
Old Nov 23, 2007 | 08:22 PM
giantjoe's Avatar
giantjoe
The manual says that you can actually select whether or not you want to run the DRL. You can actually select them?? Unheard of in Canada. Is it worth $10K to you to import it, cause that is the price difference between Canada and USA.
Old Nov 23, 2007 | 08:24 PM
Stefx's Avatar
Stefx
You do not know the price difference, because the 2008 configurator is not up and running on the Canada Mini Cooper site.
for the 2007 model, the difference was 7k. With our dollar on par, 7k is well worth the 6% custom fees plus the cost of converting the speedometer to km/h.
Old Nov 24, 2007 | 06:39 AM
Krut's Avatar
Krut
Would you have to convert the main faceplate to KPH if the tach also displays it? If I lived in New Brunswick/Quebec or anywhere else in Canada, I would definitely be buying in the US.
The only noteworthy option you can't get here is this electric front windscreen defroster. Also, you have less customization in Canada vs. the US.
Which dealer are you going to be working with? Buying off the lot?
Old Nov 24, 2007 | 11:14 AM
Stefx's Avatar
Stefx
From what I understand, in Canada your speedometer needs to be modified to display km/h. Also, the car needs to have 5 mph bumpers (do you know if the Mini USA has that?)
I don't know where I will buy it yet. My estimates, including the various fees, show savings of 6-7k on a regular Mini (loaded with options).
I have a thread in the Canada section where I will list the details.
From the pics I see of the speedo on the US and Canada site, the max speed are the same 150mph / 240 kph, so I assume it just needs a faceplate change, not an actual changing of speed instrumentation or anything.
Old Nov 24, 2007 | 01:10 PM
Mowse's Avatar
Mowse
Speedo MPH vs KPH
That is my only dissapointment in the R56. I miss the old center speedo that had bot MPH/KPH plus the needle gauges. I like the size but it looks empty.
Old Nov 24, 2007 | 02:38 PM
jggimi's Avatar
jggimi
Originally Posted by lacning74
While the electronic OBC will display mph, it is not the default display and would require you selecting it everytime you start the car....
Not quite: on my US R56, the "mode" you set the tach display to will stay as-is between starts. So one could use the kph display there full time without having to reset every start.
Old Nov 24, 2007 | 02:47 PM
LOP's Avatar
LOP
I agree
Old Nov 24, 2007 | 03:13 PM
Krut's Avatar
Krut
As well as displaying liters/100 km, kilometers/litre, and imperial or us MPG, and Celcius or Farenheit!
shorenetworks
Nov 4, 2019 06:18 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
randeez
Oct 5, 2015 09:23 AM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
