R56 15" wheels on a 2007 MCS
Old Nov 11, 2007 | 03:38 PM
scottab36's Avatar
scottab36
Solved
Problem solved...
Old Nov 11, 2007 | 03:52 PM
jyarrow's Avatar
jyarrow
My understanding is that the 15inch OEM wheels won't fit the MCS because the brakes are bigger. I've heard that Sport Edition makes a 15inch wheel that will fit the MCS - info and the wheel available at Tire Rack. But that doesn't help your situation. I don't know if there is a solution. You might want to do a search over in the tire and wheel forum. Good luck!
Old Nov 11, 2007 | 03:53 PM
MotorMouth's Avatar
MotorMouth
no 15" oem wheel will fit the front of a 2007MCS. The brake caliper is too big.
Old Nov 11, 2007 | 03:57 PM
scottab36's Avatar
scottab36
Thanks for the help.
Old Nov 11, 2007 | 04:07 PM
Crashton's Avatar
Crashton
That is a possiblility, but you will have to make sure your lug bolts are long enough to work. That is very important. Me, I'd sell them & buy a set of 16" wheels for winter use.
Old Nov 11, 2007 | 04:24 PM
scottab36's Avatar
scottab36
Thanks.
Old Nov 11, 2007 | 04:40 PM
Crashton's Avatar
Crashton
I think you will be able to sell them fast in the market place here on NAM.
Good luck.
Old Nov 11, 2007 | 06:25 PM
r56mini's Avatar
r56mini
So will all 16" OEM's fit?
Old Nov 11, 2007 | 06:32 PM
Crashton's Avatar
Crashton
Yes the 16's will fit. The standard rim size on a R56 MCS is 16 inch.
Old Nov 11, 2007 | 07:02 PM
MotorMouth's Avatar
MotorMouth
I wouldn't guarantee any pre-07 16" oem rim will fit (specifically thinking of x-lites) . to get the JCW from the factory in 06 you had to get 17" rims because of the larger brakes. I think only the 16" bridgespokes (which you can still get) will fit.
Old Nov 11, 2007 | 07:07 PM
Crashton's Avatar
Crashton
No guarantee, but I believe you may be wrong about that. Maybe you should post the question in the wheels forum.
Old Nov 11, 2007 | 08:24 PM
Bhatch's Avatar
Bhatch
I have 16" 5star R53 mini wheels on my MCS R56 for winter. No issues what so ever.
Old Nov 11, 2007 | 10:27 PM
oldopelguy's Avatar
oldopelguy
16
Plenty of us R56 MCS owners looking to part with our S-winders so you should be able to pick up a set of them pretty cheap. Check out the marketplace.
Old Nov 11, 2007 | 11:19 PM
MotorMouth's Avatar
MotorMouth
good to know!
Old Nov 12, 2007 | 03:42 PM
johne123's Avatar
johne123
Perhaps it's obvious
Perhaps it's obvious only to me but why not put snow tires on your stock 16" wheels and upgrade to something else for the summer. That's what I'll be doing.
SosoMINI
Nov 22, 2015 03:17 PM
eatsleepautox
Oct 30, 2015 06:46 AM
ltjpunk7
Sep 6, 2015 07:32 AM
mini-medic
Aug 18, 2015 09:13 AM
jrezzo
Aug 9, 2015 10:32 PM
