Drivetrain Under-sized Bearings
Old Nov 8, 2007 | 02:42 PM
Haggardsk8er's Avatar
Haggardsk8er
Well I spun my #3 bearing and had my crank checked to see if it's turnable and it is... However... The only under-sized bearing's the dealer sells are 10 thousands and I need 20 thousands... Anybody know where I can get a set or am I s.o.l. and now need to buy a new crank? And do I need to have the crank main bearing journals turned as well because they are not damaged!!!
Old Nov 8, 2007 | 03:31 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I can guess what happened, but care to spell it out?
I have no idea where to get engine internals...
Old Nov 8, 2007 | 05:03 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
If you need a new crank...
STROKE IT!!! Call Jan and get some more liters.
Old Nov 8, 2007 | 07:02 PM
MRmidge's Avatar
MRmidge
If you need bearings, check in your phone book for a specialty bearing shop. If you live near Philly i could get you directions to a shop in Pottstown that does bearings for any imaginable application. If not you might be able to find something similar to where you live.
Old Nov 8, 2007 | 07:34 PM
UKSUV's Avatar
UKSUV
We already know what happened....
Old Nov 8, 2007 | 07:35 PM
UKSUV's Avatar
UKSUV
You can always go to another aftermarket car tuner (I.E. one for SRT's, Evo's, etc.) if you know the specs.... It's an option if you have nowhere else to turn.
Old Nov 8, 2007 | 10:07 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
ok. spun a bearing...but he ran out of oil? pushed it too hard? ran too much boost? this is what i wanted to know i guess. the cause for the spun bearing.
Old Nov 9, 2007 | 10:08 PM
herbie hind's Avatar
herbie hind
so just the rod big end? seems a common mallady with this car . you should be able to just do the big ends and leave the mains alone . maybe jan or endyne.
Old Nov 10, 2007 | 11:08 AM
Haggardsk8er
Well the bearing spun when I popped the #1 piston running 24psi on stock internals... Ooops.... Was fast as hell tho!!!
Old Nov 10, 2007 | 11:09 AM
Haggardsk8er
Well the rod's are forged and snapped off so they have to be a "perfect" match or else this will happen again....
Old Nov 10, 2007 | 11:10 AM
Haggardsk8er
Already thought of that my friend!!! But rebuilding the full-race set-up Is WAY out of budgit right now... I've already called and talked with Jan, that was my first idea
Old Nov 10, 2007 | 11:11 AM
Haggardsk8er
I don't live near Philly, Im in Arizona but if you have the number I'll take it
Haggardsk8er
Haha.... Glad someone is paying attention
Old Nov 10, 2007 | 11:12 AM
Haggardsk8er
AWESOME!!! Just graduated to 3rd gear!!!!!!!!!!!
Someone reward me with a crank =)
Old Nov 10, 2007 | 11:14 AM
Haggardsk8er
Elaborate on "if I know the spec's" because I have all the journal sizes and bore sizes and every measurement for the block and internal's... But what can I do, have a set of bearing's made???
Old Nov 10, 2007 | 08:25 PM
herbie hind
sooo, no one like madness or mania is doing undersized? that bites. what's beemer want for a crank?
Old Nov 11, 2007 | 06:21 AM
cristo's Avatar
cristo
Alliance Member
Looking at a couple online sources for MINI parts, I see prices of $1225-1460
for a new MCS crankshaft with bearing shells,
or $585-774 for a remanufactured one with bearing shells.
Interestingly the cast MC crank is the same price as the forged MCS one new,
and only about $75 cheaper for the remanufactured ones.
Old Nov 11, 2007 | 08:18 AM
Beecher's Avatar
Beecher
you can get your cranked welded up, and ground back to stock, or .010 under on the one, and grind the rest down to .010 so they are all done and new. Might be hard to find a place to do this tho, im blessed enough to have a shop that specializes in crankshafts about an hour from me.
Beecher
Old Nov 11, 2007 | 08:20 AM
Beecher's Avatar
Beecher
actually, if you decided to get a new one, or get one out of wrecker, i might be interested in yours. thanks
Beecher
Old Nov 11, 2007 | 09:58 AM
Haggardsk8er
Beecher
Well too bad I'm not in canada... I wish I was could get a hold of that guy in Canada you know... I have no idea what I could even get it to you for... We'll see....
Old Nov 11, 2007 | 10:06 AM
Dr Obnxs's Avatar
Dr Obnxs
They have phones in Canada...
and the shipping is shipping. If you value it as worthless as a used car part, there are no duties as well.
Lots of places used to spray (not like spraypaint though) metal onto cranks and cams to build them up prior to resurfacing. Don't know if it's a lost art or not.....
Matt
Old Nov 11, 2007 | 10:11 AM
Haggardsk8er
Any prices on what it cost's to get it built up and ground?
Old Nov 11, 2007 | 10:26 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Good luck with what ever route you go. I may be looking into this Stroker my self...Budgets, I wish they did not exist.
6TH GEAR!!! WOOT!!!
Old Nov 11, 2007 | 10:32 AM
MINIdave's Avatar
MINIdave
If you're on a budget, what Beecher suggested is the least expensive way to get you back on the road, just find a good speedshop in your area in the phonebook, if they don't do it, they'll know who does.........
As an aside, I heard this is basically the same motor used in the Neon, any crossover there?
Old Nov 11, 2007 | 03:02 PM
Beecher's Avatar
Beecher
i would just have it shipped to the states anyway. Was it a main or rod big end you spun? I mentioned this in the marketplace thread, but if im not working tomorrow, i will phone my local shop to see, that way you have at least one idea on cost. We will see what happens before we start into the shipping conundrum. I have so many planned upgrades right now, it hurts my brain just trying to decide what to do first (just a teaser, standalone ecu, independent throttle bodies, race cam, and maybe some more displacement as well, well actually, the ecu has to come before the cam and bodies anyway, but a head is also in the works, but beefing internals might be my best place to start).
Do you see what i mean. I should never make a plan without a schedule, cause this is where it leads me. haha
Beecher
