R50/53 Need help on this one...
Old Nov 6, 2007 | 12:57 PM
nwxtwarhol's Avatar
nwxtwarhol
here is my problem:2005 mcs
1. spark plug popped out (previous owner stripped it, so warranty wont fix)
2. rethreaded head
3.new plugs and wires
4.reset computer
I still cant get the car to run. idles like it is still missing a plug. I am getting spark, fuel, and @150 compression on all cylinders.
can anyone out there help me
Old Nov 6, 2007 | 01:00 PM
Gromit801's Avatar
Gromit801
When you say you reset the computer, what do you mean exactly?
Sounds like the ECU need a reflash.
Old Nov 6, 2007 | 01:15 PM
billie_morini's Avatar
billie_morini
Q: when you say, "rethreaded head," do you mean material was inserted into plug hole and threads were cut in it?
Old Nov 6, 2007 | 03:57 PM
trackster's Avatar
trackster
The most common fix for this is a Heli Coil. Not sure if that was what he used or not.
Old Nov 7, 2007 | 04:15 AM
nwxtwarhol's Avatar
nwxtwarhol
I used a timesert thread insert (better than a helicoil) commonly used on 911 porsches.
Old Nov 7, 2007 | 04:18 AM
nwxtwarhol's Avatar
nwxtwarhol
I reset the computer using the ignition switch and speedo reset button technique i read about in another forum thread. It resets the eml for a little while but the car eventually goes back into "limp mode"
Old Nov 7, 2007 | 04:37 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
2. rethreaded head
4.reset computer
Put the old wires back on and see what happens.
I changed some wires on my MCS this last May and it was firing on only 3 of the 4 cylinders. One of the new wires was bad.
Old Nov 7, 2007 | 05:24 AM
daflake's Avatar
daflake
Wires will do it... It you are not getting a solid spark, that will cause problems.
Old Nov 7, 2007 | 06:30 AM
nwxtwarhol's Avatar
nwxtwarhol
idid the wire switch back and forth, old plugs back and forth, still getting good spark..taking it to the dealer tomorrow..(with vaseline)
Old Nov 7, 2007 | 07:48 AM
dansmini's Avatar
dansmini
I thought that it was determined that the trick of "re-setting" the ECU via the speedo / ignition trick does not actually re-set the ECU. I will look for the thread I saw that on...
Ahh, found it: Look at post #5 and read on:
https://www.northamericanmotoring.co...ight=ecu+reset
Old Nov 7, 2007 | 11:25 AM
nwxtwarhol's Avatar
nwxtwarhol
thanks guys car is at dealer awaiting service...hope they dont rake me over the coals..it will still be cheaper than the 5 grand they wanted to fix the stripped plug in the first place!
Inziladun
Sep 3, 2015 10:35 AM
howdyem
Jul 17, 2007 10:25 PM
MBR
Off-Topic :: Autos
May 24, 2007 06:22 PM
Methius
May 9, 2007 08:05 AM
Nomonstersinme
12
Jan 31, 2003 06:15 PM
