Suspension Bump stop question
Old Oct 12, 2007 | 11:17 PM
Jason C's Avatar
Jason C
Bump stop question
Yes I did a search.
I am installing H-Sport springs on my 04 MCS. I got these used without the H-sport supplied bump stops. I have found info on cutting the front OEM bump stops, but have not seen anything on cutting the rears. Is it necessary / recommended to cut the rears and if so how much?
I have sent a couple of emails to Hotchkis and Detroit Tuned but have gotten no response.
Thanks,
Jason
Old Oct 13, 2007 | 05:38 PM
txwerks's Avatar
txwerks
IMHO? Cut both front and rear in half... It's highly unlikely that you'd ever be on your rear bumpstops, but go ahead anyway.
Old Oct 13, 2007 | 06:57 PM
Jason C's Avatar
Jason C
Thanks. I have already put them on. I cut the fronts in half but left the rears alone. I hope I don't have any problems, but if I need to redo the rears it's easy enough.
One more thing. Does it matter which way the front bumpstops go back on once cut? Does the cut side go up or down, or does it matter?
Thanks,
Jason
Old Oct 14, 2007 | 07:54 AM
txwerks's Avatar
txwerks
Won't matter which way they are oriented...
If you hit the stops in the rear, you'll know it - then you can trim them if needed.
Old Oct 14, 2007 | 03:08 PM
Jason C's Avatar
Jason C
Thanks for the help.
Jason
silence2-38554
Nov 12, 2015 09:39 AM
elightbo
11
Sep 2, 2015 08:00 AM
G1HQ
Aug 28, 2015 01:41 PM
mini yellow-haa!
Aug 13, 2015 11:18 AM
massmini03
Aug 12, 2015 11:19 AM
