Suspension Sway Bar Link Detached on Driver's Front - PHOTOS
So I had a fellow NAM restore a MCS I'm driving to stock from Hsport springs. Unfortunately due to unforeseen circumstances he had to rush at the end and it seems the front sway bar link is detached.
Pics: http://www.jae-designs.com/MiniStuff2/
I didn't have a 16mm wrench on me at the time so I was unable to loosen the bolt. However, it really doesn't seem like to me that the sway bar link can even fit as it is pretty much stuck there in position without much play and there isn't enough room to attach it... thoughts?
First of all, that link can't be reused.
I have never seen that happen before, very odd that it pulled apart like that.
Get a set for both sides, just to be safe.
there is no difference in the end links between all the MINIS, R50 or R53...auto or manual. The only difference was in strut design of the early make 2002 models. They had a different mounting point on the strut for the end link which was changed and has remained the same since.
Based on the picture and the loading of the swaybar, I'd guess you only jacked up one side of the car; is this correct? As such, when you go to put the replacement drop-links on, you'll have to jackstand both sides of the front to unload the swaybar.
^^^^ he is correct, the best way to put on new links is to have the car even side to side, and the easiest way to do that is jack up the entire front end...like Ryephile stated.
If that does not work for you, you can also put the car up on ramps, so you have room to crawl under there and install them that way.
I have never had any trouble installing them with the front end up. Make sure to put a 17mm box end wrench on the arm side when tightening, you don't want that part to spin when tightening the nut.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
minipopkart
Aug 13, 2015 05:22 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
