Outside Temperature Gauge Off
Old Sep 28, 2007 | 05:12 PM
MINI_Britta's Avatar
MINI_Britta
I've been noticing lately that my outside temperature gauge is off by about 10 degrees. I figured maybe AZ's heat was too much for it and when it got in the 100s, it was just off... no biggie. But even when it's in the low 70s in the morning it says it's in the low 80s. It's starting to get really annoying. Any ideas as to why this could be? Also, I haven't done anything the should have affected it - they only mod I've done in that remote area is a 17% reduction pulley.
Thanks for any advice!
Old Sep 28, 2007 | 09:11 PM
chpsk8's Avatar
chpsk8
Can you find the sensor? I think it's behind the front bumper. I'd look and see if it's still hanging in the right spot. My Lexus is off by 3 degrees, we just call it optimistic. 10 degrees would be annoying for sure.
Old Sep 29, 2007 | 05:09 AM
cristo's Avatar
cristo
Alliance Member
Mine is usually about 5 -10 degrees high when I get in the car, but after I
get moving for a couple minutes, it's drops down to an accurate temp.
Old Sep 29, 2007 | 09:25 AM
MINI_Britta
Yeah, that's normal. But I could drive for an hour and mine would still be 10 degrees high.
chpsk8,
I'll check to make sure the sensor is hanging in the right place.
Old Sep 29, 2007 | 10:39 AM
cristo's Avatar
cristo
Alliance Member
Well, that's not right.
Have the dealer put a new sensor in under warranty.
Unless they determine the Espelir springs void the temp sensor's warranty.
Old Sep 30, 2007 | 05:51 PM
rwkeating's Avatar
rwkeating
You know the speedometer isn't accurate either. If we can't be trusted to know our real speed, how can you possibly think we can be trusted to know the real temperature
Old Sep 30, 2007 | 07:21 PM
Some Guy's Avatar
Some Guy
I wouldnt worry about it. I believe someone once said that because the sensor is so close to the ground it does a better job of measure pavement temperature than air temperature. I have seen where the thing is and that idea make a lot of sense.
imncrxtc
Jan 19, 2018 03:16 PM
Doc Pain
Oct 28, 2015 07:09 PM
papawhiskey
Sep 30, 2015 02:50 PM
gnhovis
Sep 28, 2015 04:07 AM
rt808
Sep 25, 2015 01:59 PM
