Connecting Rod Torque Specs
Old Sep 19, 2007 | 05:38 PM
Haggardsk8er's Avatar
Haggardsk8er
Installed new rod bearing's.... Anyone know the torque on the connecting rod's? I don't have the book and lost my paper that told me... PLEASE HELP :impatient
Old Sep 19, 2007 | 05:53 PM
002's Avatar
002
Replace the bolts, 20Nm, then 90*. This is for a stock connecting rod.
Old Sep 20, 2007 | 01:41 AM
Haggardsk8er
Thank you much!!!
But I don't get the 90 degree's....
Old Sep 20, 2007 | 04:40 AM
chadtoolio's Avatar
chadtoolio
After you tighten the bolts to 20nm, turn another 90 degrees with a torque angle gauge
Old Sep 28, 2007 | 04:16 PM
Haggardsk8er
Chad... I thought you told me 30 the other day???
Which is it... 20 or 30???
Old Sep 29, 2007 | 06:13 AM
herbie hind's Avatar
herbie hind
stage 1 - 15 ft. lbs.
stage 2 - 90 degrees
you can use white out to mark the bolt to the cap after stage 1 then go the 90 .
Old Sep 29, 2007 | 03:54 PM
002's Avatar
002
20 is the factory spec for new factory bolts.
Old Sep 29, 2007 | 04:17 PM
chadtoolio's Avatar
chadtoolio
Must have been late for ya buddy>)
Text message said: " What do I torque the cam bolts too?"
Old Dec 10, 2019 | 01:02 PM
Beka_2JZ's Avatar
Beka_2JZ
So is it Okey to go for 40NM ?
instead of 20 NM + 90 degrees ?
I've changed rod bearings and my engine builder guy said that 40 NM was okey.
do i have to worry about that ?
my engine is N18 turbo.
Old Dec 19, 2019 | 02:16 AM
Beka_2JZ's Avatar
Beka_2JZ
hey, anyone ?
Old Dec 23, 2019 | 12:02 PM
You are in the wrong thread. This is for the W11 engine, not the N18 engine.
N18 engine : https://www.newtis.info/tisv2/a/en/r...rings/DJ8V4Xwe
Filmy
15
Jun 6, 2023 06:27 AM
minimofo
Sep 30, 2015 12:26 AM
one73ronin
23
Sep 22, 2015 09:56 AM
cw40342
Sep 2, 2015 06:01 AM
