Reverse Light Wont Work
Old Aug 29, 2007 | 08:56 PM
burley's Avatar
burley
I though the problem was just a bulb, but after replacing it, the problem still lingered.
I checked the fuses, and Im not sure if theres one just for the reverse light. Every other light works fine. Any suggestions?
Its nice to be able to see when backing up... Kinda used to it...
Old Aug 30, 2007 | 01:09 AM
mylittlemini's Avatar
mylittlemini
the fuse for the reverse light is F13 in the interior fuse box.
if its not the fuse then it could be either the reverse switch if you have a manual or the cvt switch if you have a cvt.
check the fuse, if its ok then check to see if it is getting powered, if it is getting power then its pretty possible its the switch.
Old Aug 30, 2007 | 04:16 AM
snid's Avatar
snid
It's probably the switch. I had mine replaced. It's one of the few old school, mechanical things on the car, and it wears out.
Old Aug 30, 2007 | 08:16 AM
burley's Avatar
burley
Fuse is OK. I swapped it just to play it safe, and still wont work. How much for a new switch and can I do it or do the dealer have to?
Old Aug 30, 2007 | 09:25 AM
snid's Avatar
snid
I forget what the cost was for the part, but it was pretty cheap. It is something in theory that you could do yourself. But, without a lift to put the car on, it's probably better to let the dealership do it. It shouldn't cost much at all, because it's a pretty easy job, and they've probably done it a bunch of times so they know what they're doing.
Old Aug 30, 2007 | 09:38 AM
rkw's Avatar
rkw
Here's a thread with more information: https://www.northamericanmotoring.co...ad.php?t=49413
Old Aug 30, 2007 | 05:40 PM
Its311pete's Avatar
Its311pete
reverse switch, common problem
Old Aug 30, 2007 | 06:28 PM
snid's Avatar
snid
Yup, in that other thread I posted after I got the work done... $40 parts & labor. At that price, might as well just have the dealership do it.
Old Sep 5, 2007 | 12:29 PM
burley's Avatar
burley
Baron Mini in Kansas City wanted 160 bucks.... they also said its only a $20 part...
So maybe I'll take it to a local garage or just do it myself.
BoCRon
Aug 17, 2015 01:21 PM
stellaherself
Aug 14, 2015 05:28 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
