JCW carbotech brake pads... available.
Old Aug 29, 2007 | 03:29 PM
rutherfong's Avatar
rutherfong
Like most jcw brake owners, I've been patiently waiting for a less dusting, non corrosive brake pad alternative to OEM. I have been randomly calling various companies to check on availability. EBC and AXXIS apparently have p/n 's for our brakes, but no product.
I just got off the phone with Carbotech, and apparently, the long awaited backing plates for the front jcw brake pads are in. I placed an order for a set of front and rear in the bobcat compound (street driving only). They claim I will have them in 2 weeks. Fingers crossed. I just hope I didn't get on a waiting list.
Old Aug 29, 2007 | 03:37 PM
Crashton's Avatar
Crashton
Great news. That sure took longer than I thought it would.
Old Aug 29, 2007 | 08:08 PM
cct1's Avatar
cct1
Has anyone done a how to on changing the (front) JCW brake pads? Octaneguy did a great one for the rear brakes, which are the same on the JCW setup except for the pads, so that DIY will work for the rear, but the front calipers are completely different.
Old Aug 29, 2007 | 08:18 PM
PGT's Avatar
PGT
in for feedback...I'd like better initial bite vs. the stock JCW compound
Old Sep 16, 2007 | 10:30 AM
CARdiac's Avatar
CARdiac
Is there and update on this?
Old Sep 28, 2007 | 11:12 AM
johnmdanskin's Avatar
johnmdanskin
If you can replace the rear pads you can replace the front pad. It's just easier.
Remove the two bushings (7mm allen screw).
Take pad holder thing off
Remove the pads
Compress the piston (I have a tool, but you can use a c clamp or really big channel-locks)
Put the new pads in
Put the pad holder thing back on.
Look at the ground and see if you forgot anything.
Double check that you tightened everything.
All done.
The big difference from rears is you don't have to spin the pistons while compressing.
I was just trying carbotech XP9 in front for the track and a friend of mine was trying XP10. I got 4 days. He got 1.5 days and actually welded a backing plate to a piston which ended up resulting in a flat bed ride. He was checking his pads, but the inside wore a lot faster than the outside and he was also really expecting more than 1.5 days.
I've decided that I can't afford carbotech for the track.
I don't know about the bobcats on the street. I have two friends who had 4 wheel offs on the track due to not stopping when they wanted to stop. As far as anyone can tell, it was the pads.
I liked my xp9s while I was driving but the wear is too much.
I was using XP12 on a more powerful car and they wore fast, but not this fast. That car had $750 rotors, so pad wear wasn't my big concern and carbotechs are easy on the rotors. On my mini GP the pads cost more than rotors.
Old Sep 28, 2007 | 11:51 AM
PGT's Avatar
PGT
did you get new aftermarket pads for your GP or no? that's what this thread is about
Old Sep 29, 2007 | 09:21 AM
tazio's Avatar
tazio
I am about ready to replace my my front JCW pads so am also interested in any updates...
Also, any good aftermarket rotors available yet for these brakes? The new OEM JCW rotors are an option, but wondering if there are others yet.
Old Feb 14, 2008 | 01:41 PM
sranderle's Avatar
sranderle
Any more updates on the Bobcats for street use?
Old Feb 15, 2008 | 06:40 AM
Gaan's Avatar
Gaan
johnmdanski...that is not good news about the xp10's. based on my conversation with ctbrakes, i went with xp10's on my previous 3300 lb fwd car with R compound and was very pleased. i got 2 events on them and they're about 50% worn afterwards. not too bad i thought. much better than the ebc yellow stuff that was the only available track pad option. i would think on a much lighter car like the Mini, it would wear better. i guess we'll see.
thanks.
theblackfalcon
Oct 11, 2015 09:49 AM
bjcarter2
Aug 31, 2015 04:03 PM
nomar116
Aug 10, 2015 11:24 PM
