Interior/Exterior Removing Rear "Vents" from MCS Bumper
Old Aug 27, 2007 | 06:00 PM
bee1000n's Avatar
bee1000n
Does anyone know how to remove the black, plastic "vents" from the bottom of the rear MCS bumper? I tried using a credit card to find tabs (like when removing the cowl vents), but I didn't have any luck.
If you have removed them, what does the bumper look like without them? I think it might look better without the vents, but figure there could be conspicuous holes left from the tabs.
Old Aug 27, 2007 | 06:07 PM
MUShadd's Avatar
MUShadd
mine shows the ugly shiney heatshield film...i need to get unlazy and paint it black to hide it better.
Old Aug 27, 2007 | 06:51 PM
PhysicsGeek's Avatar
PhysicsGeek
Not that greatest pic for showing what you want. But with the Aero rear I cut out the openings and installed grill mesh instead. I painted the rear heat shield black, but I will eventually remove it when I do a exhaust system.
Old Aug 28, 2007 | 08:37 AM
omascow's Avatar
omascow
There are 4 tabs towards the corners, at least I from what I remember it's been a while since I worked on them. But they pop inwardand then you can just pull them off. I used tin snips to cut the exhaust heat shield down so that it didnt show through the vents when I was done with them. It's quite easy. And don't worry about breaking the tabs on the vents, I wrecked one and bought a replacement from the dealer for $10, so they are not that expensive.
Old Aug 28, 2007 | 09:14 AM
bee1000n's Avatar
bee1000n
Thanks, folks. I was hoping the regular MCS bumper would be the aero kit and that there would be a flat, body-color panel behind the vent. I guess I'll leave 'em in.
Old Aug 30, 2007 | 09:35 PM
markldriskill's Avatar
markldriskill
I think m7 has cool-looking "Ultimate" rear grilles to match the fronts they offe (available in black or silver powdercoat).
Old Sep 3, 2007 | 10:30 PM
COR BLMY's Avatar
COR BLMY
PUSH ... just a bit more. They will come out.
I trimmed the heat shield and added mesh
Old Sep 4, 2007 | 09:32 AM
eager2own's Avatar
eager2own
PhysicsGeek and CorBlmy --
how did you attach the screens to the inside of the bumpers?
Old Sep 4, 2007 | 12:31 PM
COR BLMY's Avatar
COR BLMY
I very carefully cut the mesh at the OEM tabs so that they "hook" onto those tabs.
The mesh is about 1 inch larger than the hole.
I can do this mod without removing the rear bumber
Will try to take a close-up photo for you
Old Sep 4, 2007 | 01:23 PM
JIMINNI's Avatar
JIMINNI
Your only the second car iv'e seen with that rear bottom spoiler. Fracky from my city has one too .
Old Sep 4, 2007 | 02:51 PM
hosmer's Avatar
hosmer
skippermini
Aug 12, 2015 10:05 PM
xraycat
Aug 12, 2015 02:36 PM
dyeLucky
Aug 7, 2015 07:10 AM
bctf1
Aug 6, 2015 12:55 PM
