Passenger window won't go down??
Old Aug 21, 2007 | 07:51 PM
jjasonbbo's Avatar
jjasonbbo
my 04 MCS power passenger window won't roll down.... it doesn't even move when you open the door??? is there a seperate fuse for each window??
Old Aug 31, 2007 | 12:27 PM
Its311pete's Avatar
Its311pete
Your problem resides in the window motor. replace the motor and enjoy all the thrills of a working window again.
Old Sep 2, 2007 | 03:53 PM
vitaminC's Avatar
vitaminC
It's probably the motor. Mine wouldn't go down when it was hot outside, then eventually not at all. It was fixed under warranty.
Old Sep 2, 2007 | 04:03 PM
skillet's Avatar
skillet
Mine just did this a couple of weeks ago... but it works now. Don't know why except that it was really hot outside, and while I was rolling the window up, a buddy of mine shut the door and when it closed, it stopped and wouldn't work for the rest of the day... :impatient
Old Sep 4, 2007 | 05:22 AM
ProfessorDave's Avatar
ProfessorDave
Do the "bang the door" technique...it generally works for awhile (when it stops working, then go for the new motor, which is around $80 for the part). Here's how you do it (you can also do a search on this topic, as others have posted on it, which is how I found out about it):
Bang the door with the afflicted window just above the lower speaker while you simultaneously flick with window switch (the bang alone might get the motor working).
Good luck!
Old Sep 4, 2007 | 09:26 AM
weaverpsu's Avatar
weaverpsu
Don't run out to replace motor
I recently went to the dealership for other problems and mentioned that the windows on both sides stopped working. He got in, held the window switch down and banged once above the speaker and it worked, then he did the same on the other side. He said something like the motor resets itself and it just needs a little bump to work again. I banged a bunch of times but he knew exactly where the motor was and since then on a hot day it didn't work. Held switch down while doing a bang and walla! perfect again.
Old Sep 4, 2007 | 10:16 AM
Its311pete's Avatar
Its311pete
You wil at some point in time have to replace them, they are on there way out.
Old Sep 4, 2007 | 10:28 AM
mcs22004's Avatar
mcs22004
I think of it as window roulette. It's a nice surprise when the windows work.
Old Sep 11, 2007 | 04:19 PM
gone_motoring's Avatar
gone_motoring
ahhh, I had never tried the "banging the door while activating the switch" technique. (I've just banged the door :impatient ) Good to know! Interesting, it does seem this happens to others like me - just when its summer!
UncDeo
Nov 4, 2019 04:08 AM
Ntety
Sep 2, 2015 08:39 PM
hardy616
Sep 2, 2015 08:32 AM
spackletooms
Sep 1, 2015 10:12 PM
