Suspension rear clunk
Old Aug 13, 2007 | 05:58 PM
rjtrout2000's Avatar
rjtrout2000
rear clunk
I just installed the Alta 19mm swat bar on the rear of my car and it makes a subtle clunk noise when going over bumps. Is that normal?
Old Aug 13, 2007 | 06:15 PM
Longboard110's Avatar
Longboard110
no, recheck all your nuts and bolts you messed with during the install. Id start with the sub frame.
Old Aug 13, 2007 | 10:14 PM
rjtrout2000
Sounds like a good time! Thanks for the feedback!
Old Aug 13, 2007 | 10:43 PM
nypepper's Avatar
nypepper
if every thing is tight it could be the bushing strap hitting the body, thats what was happening on mine
Old Aug 13, 2007 | 11:03 PM
rjtrout2000
Really? WHat did you do to fix it if you don't mind me asking...
Old Aug 15, 2007 | 09:36 AM
rjtrout2000
Re-checked all connections with the subframe and anything else I may have screwed up during install, but still clunking. Wonder what gives??
Old Aug 15, 2007 | 10:56 AM
nypepper's Avatar
nypepper
used a long pry bar and a hammer to bend the the pice of the body out of the way
you just need to move it a little bit
in the end i did remove the bar all together and replaced it with an H&R that uses the factory bushing claps
Old Aug 15, 2007 | 03:48 PM
rjtrout2000
When it comes down to it, is it a really big problem if it is clunking? If it is seriously a fitment issue but the components are tight, the bar is in place, and there seems to be no problem with the performance, will it really hurt the body of the car? The clunk doesn't bother me and as of right now, it doesn't seem to be a serious issue.
Old Aug 15, 2007 | 03:55 PM
xsmini's Avatar
xsmini
Check the endlinks. Mine were tight, or so I thought, but were still clanking like crazy over the bumps.
Nik
Old Aug 15, 2007 | 10:12 PM
rjtrout2000
Nik
Awesome! Maybe I will check over them one more time! Thanks for the tip!
Old Aug 15, 2007 | 10:21 PM
wtadye's Avatar
wtadye
Coordinator :: PDX MINI Club
Check to make sure the bushings are 19mm and not 22mm.I installed an Alta 19mm bar a couple weeks ago and they sent 22mm bushings by mistake,Didn't realize until the bar was installed and had a clunk
Old Aug 16, 2007 | 11:08 AM
rjtrout2000
Hmmm, I bought the bar direct from Alta when I went to Minis in the Mountains so I figured that they would have checked this out for me. Well, that gives me another idea, but what would I look for to signify 22mm bushings rather than 19mm bushings?
Old Aug 16, 2007 | 11:57 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Nik
x2
Old Aug 16, 2007 | 03:05 PM
wtadye's Avatar
wtadye
on the end of the bushing it says either 3/4" (19mm) or 22mm.I bought the last bar directly from them as well.
Old Aug 17, 2007 | 12:20 AM
rjtrout2000
Awesome, I will check that out tomorrow! Thanks again for the help guys!
Old Aug 17, 2007 | 07:52 PM
rjtrout2000
Well, it ended up being the bushings and Alta is sending me the correct ones as we speak. Thanks again for helping me diagnose the problem.
Old May 13, 2008 | 04:41 AM
MINIdriver85's Avatar
MINIdriver85
mmh, I have a 22mm Alta rear sway bar and I have that same clunking noise...so you say to check the endlinks and the bushing straps? If it is the endlinks, how can I eliminate the clunking apart for tightening them?
Old May 29, 2008 | 05:52 AM
go_mini_go's Avatar
go_mini_go
Yes crank down on the end links. Will get rid of the noise.
Old Sep 10, 2010 | 06:47 PM
cpayne's Avatar
cpayne
Just went though this myself. It was loose and mis-adjusted endlinks. Make sure swaybar is NOT preloaded and end-links are tight both on swaybar and control arms. Mine was making clunking noises at very low speeds, that I could hear. Originally thought broken exhaust hanger but it was not. Glad hunted that gremlin down!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
emulajavi
Dec 24, 2018 09:15 AM
aldito2
Nov 25, 2015 09:33 PM
Mini'mon
Aug 26, 2015 01:02 PM
