Help with pads
Old Aug 10, 2007 | 08:04 PM
MCS02's Avatar
MCS02
MINI Alliance Ambassador
Help with pads
Hi
I need to install new brake pads on my 02 S. What is the best for street and maybe a track day or 2
Old Aug 11, 2007 | 05:54 AM
ignote's Avatar
ignote
Originally Posted by MCS02
Hi
Hawk HPS
Old Aug 11, 2007 | 05:58 AM
snid's Avatar
snid
Hawk HPS
Old Aug 11, 2007 | 07:36 AM
MCS02's Avatar
MCS02
Thanks For the Help
Old Aug 11, 2007 | 07:44 AM
cristo's Avatar
cristo
Alliance Member
This may be a little different, but how about
Hawk HPS
I like mine
got them on my wife's VW as well.
Old Aug 11, 2007 | 10:30 AM
Robin Casady's Avatar
Robin Casady
What are the characteristics of the Hawk HPS?
Do they produce less dust than stock?
Do they resist fading longer?
Any difference in brake pedal pressure or feel?
Are they noisy?
Old Aug 11, 2007 | 02:22 PM
snid's Avatar
snid
Less dust, and the dust is kinda brown instead of black
Definitely
Nope. At least not that I remember. but it has been ages since I had stock pads.
Are they noisy?
They don't squeak.
Old Aug 11, 2007 | 02:51 PM
cristo's Avatar
cristo
Alliance Member
Agree with all of the above, plus, the lesser, lighter dust doesn't stick as tenaciously
to the wheels as the stock pads' dust, so it's easier to wipe off.
About same grip as stock cold, and better than stock warmed up.
Old Aug 12, 2007 | 05:42 AM
PlayPlay's Avatar
PlayPlay
How do Hawks compare with Ferodo 2500 and EBC Red Stuff?
Old Aug 12, 2007 | 07:20 AM
pinkMINIgirl's Avatar
pinkMINIgirl
OMG - my husband made the mistake of getting Ferodo, and will be getting the ones reccommended above next time. All I can say is they are annoyingly loud, sqeeley, etc. Sounds like a tactor trailor coming to an abrubt stop
Old Aug 12, 2007 | 08:14 AM
PlayPlay's Avatar
PlayPlay
seriously? LOL....well i knew they were recommended for track use ....maybe thats why heheh
Old Aug 12, 2007 | 10:17 PM
k-huevo's Avatar
k-huevo
My experience with Ferodo DS2500 pads is different. They never made noise in the first half of their life, and in the later miles, only for a few stops after a wet drive. They perform very well when up to temp, not so great for the first cold stop, but easily compensated for. The Ferodo pads require some serious heat cycles for the bedding in process, perhaps a timid break in may contribute to noise. I’m sure there are pads better suited for an urban environment but the DS2500 are very good high speed stoppers. BTW, I’ll be trying the Hawk HPS pads the next time around.
Old Aug 13, 2007 | 05:37 AM
hornguys's Avatar
hornguys
I used Ferrodos on my first MCS, and then on my new one. Replaced the EBC greens I did have, which had replaced the OEMS. I didn't find any advantage with the Greens except less dust. The Ferrodos have seen track days and lots of auto-x events. Over 70,000 miles on the two cars with Ferrodo 2500s.
I've found them to be a good mixed-use pad. There's certainly better for track days, but they still aren't bad when occasionally used for track & street. None of the problems you mention.
Wonder if he installed 3500s, a track-oriented pad?
Old Aug 13, 2007 | 05:46 AM
mozzarella's Avatar
mozzarella
I'm running Carbotech XP 10's work well, a little noisy and very dusty but will stop you.
Old Aug 13, 2007 | 06:31 AM
bean's Avatar
bean
i had a buddy running hawk HPS on the track at homestead last weekend. they didn't work for him. i'm sure that it will depend upon driving style and experience. he was running kuhmo V-710's and has quite a bit of track time. IMHO dual purpose pads will only work on the track until you have a certain level of experience and tire grip. brake torque is great, but can be limited by tires that don't grip. if running r-comps, i would recommend a dedicated set of track pads. lots of dust, lots of brake torque, no fade. then switch back to your low dust pads for the street. it doesn't add much time to the equation if you are switching wheels/tires anyway.
Old Aug 13, 2007 | 07:36 AM
snid's Avatar
snid
You're right, but the original question was "What is the best for street and maybe a track day or 2".
Old Aug 13, 2007 | 09:44 AM
bean's Avatar
bean
thanks snid: my bad.
Old Aug 13, 2007 | 10:33 AM
welshmenwillnotyield's Avatar
When I had the Ferodo 2500s on, they drove me nuts with their squeeking and dusting, so I had them taken off after about 1000 miles and two track days. While they Ferodos were very good on the track and stopped me without fade time after time and with little wearing, I just couldn't take the other faults, so now Hawk HPS pads are on my car. I'm pretty happy with them and have used them at the track and on the street. Fade has been non-existent, as has noticeable wear, NO noise, and just that brownish, easy-to-remove dust.
Old Aug 13, 2007 | 11:07 AM
ScottinBend's Avatar
ScottinBend
Yep.....another satisfied Hawk HPS customer....!
FatherG
Oct 3, 2015 05:06 PM
little egg
Oct 2, 2015 11:19 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 08:55 AM
