R50/53 Tire warning light...
Old Jul 23, 2007 | 08:12 AM
Roeri's Avatar
Roeri
A friend and I removed my tires this weekend and painted my calipers. (Looks fantactic by the way) and I now have the tire warning light on.
I contacted DTM and asked how this can be turned off as It has happened before. They told me to hold the button for 10 seconds with the key on, then turn the key off and release the button. It worked the last time whereas it is not working now...
What gives? Did I break something? How can I get this light to go off???
Old Jul 23, 2007 | 08:18 AM
Ladidah's Avatar
Ladidah
I hate to ask, but have you done the obvious and checked all 4 tires?
Old Jul 23, 2007 | 08:21 AM
Roeri's Avatar
Roeri
For tire pressure? I haven't, but How would it have changed? I didn't let any air out or in during the process...
Old Jul 23, 2007 | 08:44 AM
Ladidah's Avatar
Ladidah
Yes pressure check them - I've found the light to be very sensitive. The pressure must be the same and even a pound low/high can trigger it.
I've had a few instances of the light staying on and it has always been a case of one tire being off a bit. It may not be your problem but it is worth a check.
Old Jul 23, 2007 | 08:55 AM
Roeri's Avatar
Roeri
I'll check that as soon as I get a chance. Is there a preferrable tire pressure for this? I know it's on the tire, however is there a preferred amount?
Old Jul 23, 2007 | 09:04 AM
minijon's Avatar
minijon
The preferred tire pressure amount for all US cars is written on the driver's side door frame.
Old Jul 23, 2007 | 01:26 PM
Mishka's Avatar
Mishka
On my 05, after pressing the button you are supposed to drive for a short distance to allow the system to reset. Have you done that?
Old Jul 23, 2007 | 11:07 PM
MotoGreg's Avatar
MotoGreg
I bought my car from someone who works for BMW and he gave me three HUGE factory training manuals that the dealer techs learn from.
Anyway, it says basically to turn the key on (engine off) and hold the RDW button for longer than four seconds. The control unit will then go into a learn mode (initialization) an then a learn phase. This phase can last anywhere from 45 minutes to several hours depending on the driving style and number of data rejections.
Old Jul 24, 2007 | 06:12 AM
MUShadd's Avatar
MUShadd
you can have any tire pressure in the tires, this is not what sets the light off. it only detects drastic change in pressure by calculating how fast each tire rotates in relation to the others.. simply turn your key on. (do not start the engine) push the button and hold for 10 seconds...actually 4 seconds will work...but do ten just to be safe. This will reset system. take your mini for a short drive. the light should turn off at some point during your trip. If you spin your tires during your drive, you will only prolong the time before the light turns off.
Old Jul 24, 2007 | 06:41 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
This is a bingo!
After holding the button in 10 seconds the light may not go out until you have driven a few miles or the next time you start your MINI after the drive.
Old Aug 16, 2007 | 10:33 PM
Fredi Pepper's Avatar
Fredi Pepper
Where is "the button"?
I'm having the same problem with the Tire Warning Light staying on (blinking) constantly. The MC is new to me, and I hate to admit it, but I can't find "The (infamous) BUTTON" to use to reset it. There is not a dealer nearby to take it to, so until I figure out how to reset it, that light is blinking all the time and slowly driving me crazy. I need a detailed description of where to find that darned button. Please help by sending me an email with info. THANKS.:impatient
Old Aug 16, 2007 | 10:48 PM
glnr13's Avatar
glnr13
look down at your e-brake. it's just to the right of it.
Old Aug 17, 2007 | 03:26 AM
umberto's Avatar
umberto
I think it is normal for this light to come on if you change a wheel....this happens every time I put my snow tires on/off,.....sometimes the light will come on right away but sometimes a day or two or three after the wheels were changed
Old Aug 17, 2007 | 07:27 AM
DixonL2's Avatar
DixonL2
Did you perhaps damage, move, or otherwise disturb one of the ABS sensors when you painted the calipers? These sensors are integral to the TPMS and, if one is reading wrongly, will throw a tire pressure warning light. Check the sensors/wiring to the wheel area as well... and you should be checking your tire pressure every month or so, it drops 1psi for every 10deg drop in outside temp...
UncDeo
Nov 4, 2019 04:08 AM
Waszak
Oct 21, 2017 05:55 PM
embiggenedmini
Oct 15, 2015 12:36 PM
jacehubbs
Sep 3, 2015 02:01 PM
Ntety
Sep 2, 2015 08:39 PM
