R56 switched power source
I'm hard wiring my V1. Tried several different unused fuse lines in the fuse box and all are constant 12v supply. Anyone know which wire leaving the box is switched to the ignition? I know that the cig lighter is switched, but don't know which wire leaving the fuse box goes there.
I'm pretty sure I've seen this answered before in the Navigation and Audio section. Someone else was looking for this for hardwiring their iPod or cel phone. I'm looking for the thread and I'll post if I can find it quickly.
I think this will point you in the right direction.
https://www.northamericanmotoring.co...=volt+switched
or possibly this one
http://www.jwardell.com/mini/fusetap.html but I don't know if applies to the R56 as well.
O.K., here is the deal: There is no switched power (as we know it) for the "acc" position, BUT many of the fuses will switch off after 30 minutes of inactivity (car off and/or locked). BMW blanks the nav display, and mutes the radio when you shut down, but all is still active behind the scenes, until the car "goes to sleep".
I have done a lot of reseach on this, and this is what I have found.
This is why almost all the fuses have +12v on them when you have the door open, and you are checking fuses for power.
I ended up connecting my Sirius to F21. Sirius powers up when I open the door, works in the "acc" position, and stays on when I get out & lock the car. It powers down after 30 minutes.
OK, with motivation from the above posts, I dug deeper. In the fuse panel on the passenger side, the blue connector adjacent to fuse F6 has a thicker red wire with a black stripe and yellow bands. This is switched on/off with the engine. I believe it goes to the cig lighter.
I had an inline tap and used it for the V1. Note, this line is at 13.5v so make sure your equipment will tolerate that. The V1 runs 11-16v as ok.
I kept forgetting to shut the V1 off when tapped into an unused fuse. This will do the trick.
I wonder if the coolant system may be the controling function. Maybe it keeps power on until the water pump has ran it's cycle?
You know, there were some discussions about mp3 disc and restarting songs. Folks were wondering why it picked up where it left off or restarted the song after shutting off the engine. I think they came to the conclusion that after about 15 minutes the system would go back to the beginning of the last track played.
This also why the heated seats "remember" if they are on if you stop the car, and re-start within the timout period.
As stated above, there are two fuses that power on/off with the engine, but this is of no help if you want power in the "acc" or radio ready mode.
What is the other on/off fuse besides F21? The "add-a-circuit" that I have will not fit in the F21 slot. The bayonets are just a bit too wide. Hopefully it is one of the wider slots in front!
They make add a circuit fuse adapters for mini fuses, this is what you need to get....you have the standard bayonet fuse adapter.
Aug 19, 2015 12:51 PM
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
Aug 17, 2015 05:09 PM
Aug 12, 2015 01:24 PM
