Suspension Should I apply Loctite
Old Jul 1, 2007 | 03:41 AM
Hattat's Avatar
Hattat
I made my final settings for the coilovers and wonder if I should apply loctite over the threads on the strut. I`m worried about the nuts getting loose and the ride height and the stiffness would change.
What do you think?
Old Jul 1, 2007 | 04:13 AM
Crashton's Avatar
Crashton
I'm guessing that may not be a good idea. I'd think the tension of the springs against the collar would hold them in place just fine.
Old Jul 1, 2007 | 04:47 AM
mozzarella's Avatar
mozzarella
What do you think?
Isn't the point of coilovers to be able to make changes?
Old Jul 1, 2007 | 04:54 AM
BigSky's Avatar
BigSky
I think it's a good question , loctite shouldn't prevent future changes just prevent inadvertent movement. It will be interesting to hear an experienced opinion.
Old Jul 1, 2007 | 06:13 AM
onasled's Avatar
onasled
If you are talking about the hight adjustment on the threaded body, then NO, absolutly do not loctite them. Your coilovers should have a jam nut system, or some type of locking device on them.
Old Jul 1, 2007 | 06:30 AM
BigSky's Avatar
BigSky
Thanks!
Old Jul 1, 2007 | 06:50 AM
Hattat's Avatar
Hattat
I don`t worry about the rear coilovers but the ones at front worries me. Yes coilovers have a jam nut system but the front springs can turn downwards because the plates over the struts turns freely in effect the springs may turn both jammed nuts loose at the same time.
Old Jul 1, 2007 | 07:23 AM
onasled's Avatar
onasled
If you tighten them up correctly, then you won't have a problem.
Most threads on coilovers are pretty sensitive. You'll really mess them up if you start dripping loctite on them.
You want the top plate to turn freely, even on the rears, as the springs twist when compressing and rebounding. Not to mention the fronts rotating while steering.
Old Jul 1, 2007 | 08:15 AM
Hattat's Avatar
Hattat
By meaning tightening correctly, am I supposed to hold the upper nut and tighten the lower nut as tight as possible?
If yes, I followed this procedure so far.
Old Jul 1, 2007 | 09:31 AM
Crashton's Avatar
Crashton
I'm thinking onasled is saying they work like jam nuts.
Old Jul 1, 2007 | 04:15 PM
onasled's Avatar
onasled
Well, yes, ...kinda. Be careful about "as tight as possible" though. Not sure which coilovers you have, but as I said, most have delicate threads. Just tighten firmly and you will be OK.
Old Jul 1, 2007 | 10:05 PM
Hattat's Avatar
Hattat
Thanks onasled , I have H&R coilovers.
Old Jul 2, 2007 | 11:48 AM
meb's Avatar
meb
Greg,
I'm responding to your photo...when I increased my front rates, my front wheels left the ground too. Having the ability to adjust bound and rebound would have helped a lot. nothing worse than flying up that hill, losing tire contact with terra firma, and, having the traction control dump forward momentum. The guys following really like that
I had the H&Rs...slightly snug and they'll never move. Part of the reason those plastic isolator/washers are there; these help the springs to revolve without applying undo stress the the hieght adjusment lock rings.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
torpeau
Oct 8, 2015 11:10 AM
daonlyillwiz
Sep 24, 2015 02:07 PM
wlfman13
Sep 17, 2015 10:05 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
