Navigation & Audio Bluetooth microphone relocation
Old May 31, 2007 | 02:16 PM
Coffeeman's Avatar
Coffeeman
Many of the people that I call, using bluetooth, complain that they cannot hear me clearly. I suspected that the microphone was on the right side of the overhead console, and I was right. The cover simply pulls off, and there are two identical slots (left & right) for the microphone. As with all BMW's, the factory mounts the microphone on the passenger side (which makes sense for right hand U.K. vehicles, but not for U.S. left hand drive).
There is just enough cable to move the microphone to the left. Pop the microphone out of the cover, then insert a small screwdriver into the slot by the cable connector. Release the connector, and snake the cable to the left side of the housing. Reconnect the cable to the microphone, and snap the microphone back in. Then snap the cover back on, and enjoy much better voice transmission when using bluetooth.
Old May 31, 2007 | 05:15 PM
Birdman's Avatar
Birdman
How did you get power folding mirrors AND col weather pkge? Web does not let you pick that
Old May 31, 2007 | 05:34 PM
Coffeeman's Avatar
Coffeeman
You are correct, the Mini web builder does not let you do this, so when I ordered, i asked my MA to try it. It worked...so I was able to get cold weather package & power folding mirrors.
Old May 31, 2007 | 07:20 PM
Birdman's Avatar
Birdman
hmmmm, I was trying to figure out why they would not allow both... seemed kinds weird...
Old May 31, 2007 | 07:23 PM
Coffeeman's Avatar
Coffeeman
Gotta be a glitch in the online ordering program. Both auto folding & non auto folding are electrically heated, so it makes no sense.
Old May 31, 2007 | 07:47 PM
speck37's Avatar
speck37
Great tip - have you gotten better feedback on the voice quality? I noticed the microphone placement in the manual and assumed it was a UK / US thing. Makes no sense to have it directed at the passenger.
Old Jun 1, 2007 | 12:29 PM
Coffeeman's Avatar
Coffeeman
Yes, everyone that I've talked to since the switch, has said that my voice was louder, and easier to hear.
Old Jun 1, 2007 | 06:01 PM
BludyL's Avatar
BludyL
I just did this and my friends are saying the same thing. The sound is so much better on the correct side.
Old Jun 3, 2007 | 05:30 AM
dbhouston's Avatar
dbhouston
I tried to do the switch over, but there was just not enough wire free. the face plate wouldn't snap back into position because the wire was too tight. Grrrr.
I am having trouble setting up the dialing, etc. The system doesn't "hear" my voice that well. All in all, the system is a disappointment. I probably should have just gotten a BT earpiece and saved hundreds.
Old Jun 3, 2007 | 05:48 AM
Coffeeman's Avatar
Coffeeman
I had to route the cable through the hole in the center of the base plate. I also tugged on the cable a bit to get as much length as was available.
Old Jun 3, 2007 | 06:51 AM
BludyL's Avatar
BludyL
I had to feed the wire back up into the the space above the upper frame. That gave me enough wire to run across to the other side.
Old Jun 3, 2007 | 07:15 AM
djam43's Avatar
djam43
Even though I dont have Bluetooth , but I have Nav with voice control, and that is the microphone that I communicate with, so I went ahead and moved it over to the drivers side. No problem, used a small fishwire and threaded it through from one side to the other, taped the connector to it and pulled it through. There was more than enough wire there to connect up.
Old Jun 3, 2007 | 07:49 AM
dbhouston's Avatar
dbhouston
Thanks for the suggestions. I'll give it another look and try.
Old Jun 3, 2007 | 10:39 AM
Robin Casady's Avatar
Robin Casady
Yes, I had to do the same thing. Better that way. Now it is using the factory authorized hole and doesn't look like a home job.
Old Jun 5, 2007 | 08:27 AM
Birdman's Avatar
Birdman
Anyone snap a picture of this, I can't picture it (without the car). ahhhh the wait begins....
Old Jul 5, 2007 | 11:59 AM
Birdman's Avatar
Birdman
I just did this "mic move" mod.
One thing, I could not for the life of me snake the wire across to the other side. So I just removed the 2 screws holding the entire roof module up, then just lightly pull it down while releasing the 6 small clips along the sides. This makes it ALOT easier, no snaking, just move the wire over. Screws right back in. The screws are the star type though, so you need a start driver of the right size.
Anyone notice which way the arrow on the top of the microphone is supposed to point? I faced mine forward, want t make sure that was right.
Old Jul 5, 2007 | 12:06 PM
Coffeeman's Avatar
Coffeeman
Birdman, you got it right.
Old Jul 5, 2007 | 01:01 PM
mini18's Avatar
mini18
anybody willing to post some pics?
Old Jul 5, 2007 | 02:20 PM
Birdman's Avatar
Birdman
Sorry, I was going to, and forgot. But, you won't need them, tust me. If they were needed, I would have needed them.
It's really easy. Just pull off the cover, put finger nails between the roof material and the plastic and pull it, snaps right off. Since the roof smooshes in a little (padded), it comes right off. Then you see everything we are talking about, clear as day.
Old Jul 5, 2007 | 03:25 PM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
From the online manual that I downloaded it looked like there were two mics, one on each side...
But since you all are saying that ain't so...I'm going to have to bookmark this thread so I can move the mic over when my Mini finally arrives.
Thanks for the info!
Old Jul 8, 2007 | 11:17 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I'm glad I came across this thread. I will fix mine when I get my car. THANKS FOR THE INFO!
Old Jul 10, 2007 | 07:33 AM
Duffer's Avatar
Duffer
I'll bet it would have cost MINI a lot of money to install 2 mic's in the first place.
Old Jul 10, 2007 | 07:37 AM
Loony2N's Avatar
Loony2N
After seeing this post when it was created, I paid close attention to my calls. No one seemed to have a problem hearing me. Nonetheless, out of curiosity, I checked. My mic is on the driver's side. Which is good, cause if it wasn't, I'd have to debate whether to move it or not.
Old Jul 10, 2007 | 07:38 AM
Loony2N's Avatar
Loony2N
"I'll bet it would have cost MINI a lot of money to install 2 mic's in the first place".
Not likely. Those mics are like .79 retail. But not likely they'd do it anyway.
Old Jul 10, 2007 | 04:02 PM
amazingrando
yeah, no kidding that aint no Neumann in there. You would not want 2 mics running anyway, it would likely make things sound worse. They should just make sure it gets mounted where it needs to!
