Suspension Eibach springs
Old May 25, 2007 | 08:26 PM
mmmboost's Avatar
mmmboost
Eibach springs
Just did an Eibach lowering spring install on my MCS on tuesday.Went suprisingly well/easy between three guys and talking, it all went together in just over 3 hrs.Anyways, onto my question obviously i've read i should go get and alignment after. I do need one its pulling a bit to the right now.But i also have a slight shake under light acceleration and cruising around at a steady speed. Almost comparable to an unbalanced wheel(s). This wasnt here before with the stock suspension everything looks to be in the right places after jacking her back up and pulling the wheels off again...any suggestions? thanks!
Old May 25, 2007 | 10:07 PM
Wagnbat's Avatar
Wagnbat
How much did it lower the car? too much, and it can stress the CV joint, causing the problem. Mine did it on coilovers. Raised the car 1/3" of an inch, and it went away.
Known issue with lowering. Do a search, and you'll find tons of info.
Old May 25, 2007 | 10:12 PM
El_Griton's Avatar
El_Griton
yep, the old cv joint problem, wagnbat is right, just take a gander at the "wanted: aftermarket spring info" thread, lots of good info in there!
https://www.northamericanmotoring.co...ad.php?t=39371
Old May 26, 2007 | 10:47 AM
mmmboost's Avatar
mmmboost
thanks guys much appreciated! bought them used so im just gonna go ahead and assume theyre weak sitting too low. so much for a bargain
Old May 26, 2007 | 11:04 AM
mmmboost's Avatar
mmmboost
well that listing only has them at "MCS Drop: 1.0" fr / 1.2" rr" not alot compared to some of them? is there a chance this is why i found them used? they got old and weak and went too low?
Old May 27, 2007 | 03:59 PM
Wagnbat's Avatar
Wagnbat
Ya... Old owner probably got the wobble, and sold them to someone else without mentioning it.
Old May 27, 2007 | 04:07 PM
jeffc's Avatar
jeffc
7th Gear
Get a alignment by someone that takes allignment seriously. I installed Tein S Springs and I got a allignment and my back tires still cupped.
I got screwed on the allignment so I just purchased Helix Rear Adjustable control arms and a new set of tires. My tires were RF and really used them for the trip to the dragon so I am not too upset about it.
Old May 28, 2007 | 04:55 PM
mmmboost's Avatar
mmmboost
ya i was more refering the the wobble than the negative camber but thanks for the feedback....crappy, people would sell something possibly knowing it was bad just to make a buck....went ahead and ordered some tsw springs, seems like they know what they're doing.
Old May 28, 2007 | 05:03 PM
Fassbinder's Avatar
Fassbinder
Picked up a vibration with mini mania springs too, just finished installing CROSS coil overs, Did not feel the vibration on roadtest
Old May 29, 2007 | 08:11 PM
Intense's Avatar
Intense
252whp 200trq RMW style
I have the Eibach Pro Kit springs 1" front 1.2" rear and no problems with vibration. Bought them new and had Les Schwab do my alignment.
Vibration could be caused by bad balancing. I did have some vibration when I first lowered the car but I had new wheels and rubber too. The balance fixed the vibration
Old May 30, 2007 | 11:31 AM
flyboy2160's Avatar
flyboy2160
make sure you seated the shock bodies correctly.
right after i put my eibachs on, i had a pull under accelleration. it turned out that one shock was sitting higher than the other. no problems in over 4 years after i fixed that.
Old May 30, 2007 | 11:45 AM
mmmboost's Avatar
mmmboost
i went ahead and put the stockies back on in the front and the vibration under acceleration went away theres now one at cruising about 45-60ish. ordered a set of tsw springs waiting on those and once i install those im gonna have the wheels balanced and an alignment done. i honestly think that it was just the springs being old and sagging it dropped quite a bit with the eibachs on alot actually....
Old May 30, 2007 | 11:46 AM
mmmboost's Avatar
mmmboost
shock bodies were all seated properly when i pulled them off yesterday to put the stock ones back on...
Old May 30, 2007 | 04:35 PM
norm03s's Avatar
norm03s
tsw springs
mmmboost, could you give us an update when you get those on please.
Old May 30, 2007 | 08:18 PM
mmmboost's Avatar
mmmboost
not a problem, anything will be better than riding on stock and saggy eibach's in the back at this point.
Old Jun 1, 2007 | 01:41 PM
mmmboost's Avatar
mmmboost
recieved my TSW's today, very prompt delivery even with a holiday! probably gonna get the d00d's together on sunday and put um on!
Old Jun 8, 2007 | 12:36 PM
mmmboost's Avatar
mmmboost
installed my TSW springs this past sunday and upon post install test ride at one point i forgot i was trying to pay attention to the ride, because it was soo nice. better than OEM. the woderfully horrible south florida roads dont even bother it anymore....still have a slight steering wheel shimmy at about 50 ish. no more shake under acceleration. gonna get an alignment soon, have the wheels balanced too just to make sure and im hoping everything should be back to normal.
Old Jul 4, 2007 | 01:39 AM
mini_macky's Avatar
mini_macky
did you get control arms after putting the eibach springs? thinking of getting a bnew set of springs
Old Jul 5, 2007 | 09:27 AM
Intense's Avatar
Intense
I have the Eibach Pro Kit springs and yes, get the lower control arms. I bought them from Eibach as well but any will do
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
