Into photography, looking to upgrade to a dslr. need help.
Old May 14, 2008 | 11:40 PM
corin.mcblide's Avatar
corin.mcblide
Hey guys,
As of now I have really gotten into photography. I have a canon G9 and I love it to death but I wish I had more control over the picture. Right now I am torn between the Canon EOS Rebel XTI, Nikon D60 , and Nikon D40x. Any suggestions? Any tips you guys can give me when looking to buy a dslr, I am kinda new to them and only purchased point-and-shoots. I know the basics but when it comes to lenses and all I am lost at sea.
thanks
corin
Old May 14, 2008 | 11:55 PM
jessicasprouse's Avatar
jessicasprouse
hey! dont feel bad about being unsure, i was completely confused when i got my first dslr. right now i have the canon rebel xti, which imo think is a great dslr learning camera. also, depending on the type of photography you are most interested in, you may just want to buy a dslr body, and buy a lens/lenses seperately. There are a lot of photo buffs here that know lots more than me, so im sure a few of them will post here, but i thought i would just share my .02. good luck!
Originally Posted by corin.mcblide
Hey guys,
thanks
corin
Old May 15, 2008 | 12:05 AM
Motor On's Avatar
Motor On
You've already gone digital so learning just got much cheaper and faster than those of us that learned to use a camera in film.
My quick and dirty rule for better images has been and continues to be:
  • Get the best support you can and learn how to use it. Good support reveals how good your lenses are.
  • Get the best lenses you can and learn how to use them. Good lenses reveal how good your sensor and post processing are.
  • Get training. Learning proper shot setup, shot discipline, workflow, and post processing from the pros helps you maximize your pixels.
  • After you've done those three things and are still not getting the quality you want should you look at whether you need to upgrade your camera. If you do this last thing first, you're going to work this list backwards and take a lot of less-than-satisfactory pictures while you do. Moreover, when you work the list backwards, you often find that you have to go back a step when one of the upper items reveals a flaw you hadn't noticed in the lower ones. Save time and money by working the list forward.
http://bythom.com/rightpixels.htm
My first question is going to be where specifically do you feel limited by the G9?
It's is certainly not a camera to scoff at when it comes to image control, esp. within the P&S market.
Old May 15, 2008 | 04:01 AM
MarkS's Avatar
MarkS
Do you shoot RAW with the G9? Use manual exposure? If not, there's certainly more to explore there while you're thinking about what you need for your next step in gear. I don't have a G9 but know people who do and they love it. That's not to say you won't want a nice dslr at some point but very often it's too tempting to think in terms of new gear as a solution.
Old May 15, 2008 | 04:16 AM
MarkS's Avatar
MarkS
Oh and you can also do some very cool off-camera high-speed sync stuff with the G9:
http://strobist.blogspot.com/2008/04...th-of-sec.html
Old May 15, 2008 | 04:53 AM
djpmz's Avatar
djpmz
cameraz
check this guy out - excellent site http://www.kenrockwell.com/tech/recommended-cameras.htm
Old May 15, 2008 | 05:13 AM
catseye's Avatar
catseye
Originally Posted by djpmz
+1 He's my photo hero.
Old May 17, 2008 | 05:10 PM
LUCK219's Avatar
LUCK219
Hey guys,
thanks
corin
I'm in the same boat - debating between the XTi and the D40. I've been going back and forth forever now, it seems like. From those two the Nikon definitely has an easier user-friendly menu!
Old May 18, 2008 | 02:48 PM
donaldj's Avatar
donaldj
Just remember that lenses are the expensive part. Once you get a camera body, you'll eventually get several lenses for it. Unless you have the $$$ to sell all the lenses and buy new ones, the costs of lenses tends to lock you into a brand for quite a while.
I have about $6000 in Canon lenses. My next camera will therefore be a Canon. Switching to Nikon would be too expensive.
From what I've seen, Canon and Nikon have very similar entry level bodies, and both are quite good. In the past, Canon has had slightly better lens quality and Nikon had slightly better flash technology. I believe they've both pretty much equalled out.
Old May 18, 2008 | 04:36 PM
corin.mcblide
yeah i use RAW and the manual focus but i do not like the G9s manual focus. i like to have full control over it unlike with the G9s wheel that isnt that precise and you can never get exactly what you are looking for.
yeah i've seen how much you can spend in lens alone. that is one of things that i am also considering, if i should get just a body and choose a decent lens to start with and build from there or if i should get the kit camera and then get into the lenses.
Old May 18, 2008 | 05:16 PM
donaldj's Avatar
donaldj
You'll have to ask yourself what you primarily want to shoot. If it's an all-around camera, you'll want something in the 28mm-135mm range most likely. These lenses can be had cheap (by that I mean between $80-500) if you don't go for anything special (ultra-wide aperture, image stabilization, professional coating glass).
I shoot freelance photography for a newspaper, and have shot for a car magazine in the past. I needed a good 70-200mm for sports (wide open aperture, too) and an ultra-wide angle lens for news stories (you need to show your subject in its environment, typically with limited room in which to work). The 70-200mm lens cost me about $1600, and the ultra wide angle (16-35mm) was about $1700. If I got more clients, I'd be going for a $5000 lens that's a 400mm with a wide aperture, too, but haven't had the need yet.
Your type of shooting will dictate your needs. If you want to shoot bugs or flowers, macro lenses can be pricey too. The important thing is not to spend too much on a body that you can't get the important stuff (lenses!) to do your photos.
Here is some of my work, by the way. If you are offended by scantily clad (or less!) females, don't click.
www.djaphotography.com
www.onemodelplace.com/djaphoto
Old May 19, 2008 | 04:17 AM
MarkS's Avatar
MarkS
Yep, speed of handling and low-light performance would be good reasons. The G9 will still make a great second camera when you don't want the DLSR, though.
I'm always tempted to suggest prime rather than zoom lenses, especially for someone starting out, because you get very high quality at a relatively low price and I think it's easier to learn to "see" at different focal lengths with a set of primes. But I know zooms are now also very good and they're convenient. On the Nikon side, for a zoom, the 18-200 AF-S DX VR is highly regarded, especially for the price (see Thom's review). It's not an el-cheapo kit lens and it's not a multi-thousand dollar lens, either. I might throw in the 50 mm f/1.8, too, for a really high quality fast prime that's very inexpensive.
Old May 19, 2008 | 07:31 AM
Sin MINI's Avatar
Sin MINI
Originally Posted by dpmc
Ken Rockwell is a dolt. He praises items he hasn't even used yet based on reviews of others. Thom Hogan on the other hand has a clue.
That said, for dSLR, stick with Canon or Nikon. Most lens and accessory selection and have been at this awhile. I have a Nikon D70 but that was more because it was on sale than any affinity I have to that brand. I've no regrets however...
Old May 19, 2008 | 10:19 AM
tsukiji's Avatar
tsukiji
true dat....
embiggenedmini
Oct 15, 2015 12:36 PM
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
