Ok I need advice and with the dreaded R56 Scoop melt starting and a wait for it to finish so I can get the dealer to replace it I started looking at options. and came across the M7 AGS-R Cold Air Intake + Turbo Heatshield
vs just the heatshield from M7. It looks like around $500 difference in price is it worth it?
John
I'm biased because I really like the Super AGS. The AGS-R has a possible advantage, though, because it brings in cold air from the scoop.
Hey Steve,
Having some weird problems with the Mini! I am going to come over at lunch. I am definitely not going crazy, Tom heard the squeak this weekend I still think it is the rear passenger side. Oh I need coolant!!!!
Steve
Is the Super AGS also an M7 product for the R56? I liked the adjustable blow off ports and was thinking that 1200 degree engine paint would work for the AGS-R.
John
The AGS-R is an unfinished black gelcoat that needs to be finished to look good. Yes the Super AGS is from M7 and I can show it to you the next time you're here.
Steve
I will try to be up there Friday if that is not going to be a problem.
Chief, go with the super-AGS! I've heard that it sounds totally bad-azz & definitely helps to isolate the heat along the filter path. Dr.Steve, great job on the short-shifter & header install!!! The FPD sounds & drives fantastic.
I think you mean the AGS-R. The Super AGS has the big open filter in the engine compartment. Is the exhaust a little louder than before?
I know, I know I have to get rid of the antenna ball topper. So many people won't think I am gay any more !!!!
I never said anything about your sexual preference I just thought that the antenna would look better with something else on top of it other then a RAINBOW ball.
