Marketplace - Archive Old Marketplace threads and posts (Read-only). Please use appropriate Marketplace forum for new posts.
FS: The rest of my mini stuff.
Old Jan 9, 2006 | 09:12 AM
motorsports3's Avatar
motorsports3
05 Cooper S Suspension - Front and rear Shocks, Struts, Springs, and both Swaybars -$150.00
17" Silver S-lites - Perfect condition with only 5000 miles. The tires are worthless and way to dangerous to drive on - $250.00
Apex-i SAFC - Used for about 1500 miles, looks brand new and comes with a wiring diagram - $200.00
Old Jan 9, 2006 | 03:13 PM
n3nyongmini's Avatar
n3nyongmini
s-lites
pm-d you. Thanks Derek
Old Jan 11, 2006 | 06:28 PM
motorsports3
SAFC info
The Super AFC II (Air Flow Converter) is the industry standard for sub computer fuel control. The S-AFC II is designed to fine tune and "squeeze" power out of existing engine setups by allowing the user to modify the fuel curve with precision accuracy. Since the act of simply bolting on performance products does not make maximum horsepower, the S-AFC II allows the user to calibrate the fuel system in accordance with performance upgrades as they are installed. The AFC modifies the air flow meter/ pressure sensor signal voltage going to the factory ECU (Engine Control Unit) to change the amount of fuel injected. The S-AFC II utilizes a VFD (Vacuum Florescent Display) to display critical data in three different modes.
Features for the S-AFC II include:
Newly designed case and user interface, single button menu navigation, 12 point fuel correction in 200 RPM increments, data storage for two different correction maps, password protection, integrated knock monitor, and 4 different display options.
The S-AFC II, while not completely universal, comes preprogrammed with 15 of the most commonly used air flow meter/pressure sensor maps. By setting the AFC to one of these programs, the user is able to adjust injected fuel amounts by +/- 50%. 12 user defined RPM adjustment points allow for fine tuning in 200 RPM increments. Fuel can also be adjusted for part or full throttle situations.
The Deceleration Air Flow Correction cures erratic idle problems for Hot Wire vehicles equipped with an open atmosphere blow off valve. The S-AFC II can also display an incredible amount of data including: Air Flow Capacity (Hotwire and Flap Type only), Engine RPM, Throttle Position, Pressure Sensor voltage, Karmann Frequency, and Air Flow Meter Correction.
The S-AFC II displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
CONCEPT:
Piggyback Fuel Computer with 12 correction points in 200 RPM increments.
CHARACTERISTICS:
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
Old Jan 11, 2006 | 06:48 PM
dairyboy's Avatar
dairyboy
So this works on your MCS?
Old Jan 11, 2006 | 06:50 PM
not-so-rednwhitecooper
how big of an improvent have you seen with the AFC?
so, does it help smooth out the power band a bit?
whats the install like? how much wiring?
Old Jan 11, 2006 | 10:51 PM
MSFIT's Avatar
MSFIT
is it safc select?
Old Jan 12, 2006 | 07:19 AM
motorsports3
Yes it works on the MCS.
I had a head, cam, and all other bolt ons. From the time I drove on the dyno until we finished tuning it, I gained 30whp with no other software.
No, it is the SAFC II not the select. This works just as well as a select would.
Old Feb 11, 2006 | 07:22 AM
minimort's Avatar
minimort
Is the Apex-i SAFC sold yet?
Dec 23, 2015 10:36 AM
joedotmac
Aug 28, 2015 01:04 PM
Dashdog
Aug 10, 2015 06:17 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
PatrikKN
Aug 5, 2015 09:10 PM
