Marketplace - Archive Old Marketplace threads and posts (Read-only). Please use appropriate Marketplace forum for new posts.
BBk
Old Jun 1, 2005 | 10:33 PM
jon.k's Avatar
jon.k
BBk
A Big Brake Kit to fit stock OE 16" and 17" wheels (some may require spacers, including S-lites). Designed for the track, this brake kit greatly increases stopping power while reducing fade.
Includes:
Forged Billet DynaPro 4 Piston Calipers - Stress flow forging re-aligns the metal's grain structure eliminating the stresses and interruptions to the internal grain structure. FEA generated radial transition design substantially increases resistance to deflection and caliper separation.
7816 "Q" compound Polymatrix Racing Pads - Operates at the lowest noise and dust level of any performance pad. Polymatrix offers high resistance to fade, long wear, and low rotor abrasion.
GT Series Rotor Mounting Hats - Lightweight and strong, these hats are specially designed for use on OE hubs without modifications or interference to the suspension or ABS components. Black anodized finish prevents corrosion and enhances appearance.
SRP Series 12.19" Vented Iron Rotors - Adds stopping power and cooling capacity over smaller diameter OE rotors. Premium grade, long grain carbon iron provides long wear with high thermal stability and resistance to distortion. Venting and cleaning action of the holes and slots reduce pad glaze, dissipate surface heat, and minimize irregular pad build-up on rotor faces. This results in smoother engagement with improved consistency and response at the pedal. Treated with silver zinc wash, these rotors resist corrosion.
Caliper Brackets and Hardware - Aluminum mount brackets with steel threaded bolt inserts are lightweight and stong. Each bracket is CNC machined for precise fit. Grade 8 or higher and AN style nuts, bolts studs, washers, and alignment shims are included in all applicable kits.
$930 shipped for plain rotors
$1000 shipped for Drilled
Brand New
Old Jun 2, 2005 | 08:58 PM
jon.k's Avatar
jon.k
Wilwood
Old Jun 2, 2005 | 11:34 PM
L0KI's Avatar
L0KI
Is this a single kit you're selling or do you have multiples? Is this your own creation or are you a reseller? Are the calipers available in colors?
Old Jun 3, 2005 | 04:09 PM
jon.k's Avatar
jon.k
there are a few sets, they are wilwood brakes. They are available in colors for an extra $150 for powder coating.
Old Jun 6, 2005 | 12:28 PM
jon.k's Avatar
jon.k
bump
Old Jun 7, 2005 | 09:37 PM
jon.k's Avatar
jon.k
+ $50 for stainless steel lines.
squawSkiBum
Oct 2, 2015 09:21 AM
HaveATank
Sep 16, 2015 08:32 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
holkki
Factory JCW Talk (2009+)
Aug 12, 2015 10:14 AM
Wagnbat
Tires, Wheels, & Brakes
14
Mar 17, 2006 08:18 AM
