JCW If a pre 06/20 B48e gets factory updates from dealer does it then need Femto unlock?
Old Mar 3, 2025 | 12:25 PM
nuck's Avatar
nuck
My JCW Clubman was apparently an 03/20 build. I contacted a tuner about a bench unlock and he asked if warranty visit software updates might require it to have the Femto unlock like newer than 06/20 cars.
The story is "starting in June 2020, all BMW, MINI and Toyota Supra DMEs were produced with an updated bootloader that made OBD flash tuning using existing protocols impossible."
To me that suggests a different ECU was used after 06/20 it but I am not clear. As far as I understand, after a tune on an unlocked ECU a dealer update will require a new bench unlock, not sending the box to Europe.
Any pre 06/2020 owners out there still able to bench unlock after a dealer software update?
Old Mar 9, 2025 | 06:05 PM
nuck's Avatar
nuck
In answer to my own question I have located threads on a BMW forum going back to 2020 where people were taking their cars in for warranty and got a lock along with their software updates. It did require a bench unlock afterwards, not a Femto unlock.
Old Mar 30, 2025 | 12:47 PM
Gelmobile's Avatar
Gelmobile
I just had my mar 21 build JCW F56 ecu successfully cloned by Modded Mini! The car is up and running, two separate ECUs stock and pre-Jun2020 cloned ECU.
Old Apr 13, 2025 | 04:55 PM
RIPPER's Avatar
RIPPER
do you mind me asking exactly how does that work? Do you swap out ECU’s and only run one at a time i.e. put the stock one away until you’re ready to sell the car or do they both run at the same time? Yes, I’m not very knowledgeable about these things.
Old Apr 13, 2025 | 05:02 PM
Gelmobile's Avatar
Gelmobile
Exactly! Running the cloned ECU until I need any factory recall/sale.
Old Apr 22, 2025 | 01:06 PM
RIPPER's Avatar
RIPPER
was it expensive to have him do it?
Old Apr 22, 2025 | 01:36 PM
Gelmobile's Avatar
Gelmobile
They have a drop down menu to determine the cost.
https://moddedmini.com/
elkay
4th Generation MINIs
Apr 30, 2025 11:21 AM
MikeMJCW
Apr 26, 2023 03:25 PM
Masonotfound
Oct 21, 2021 09:36 AM
Rob'sDad
Nov 10, 2019 07:04 PM
