ECU reset
Old Nov 6, 2019 | 08:29 PM
Rob'sDad's Avatar
Rob'sDad
ECU reset
" You have now reset your ECU and your MINI is now ready to relearn the new mods and your driving style. "
What is this all about?
I suppose the mods in question are motor mods, so how is this "learning" process going to affect my driving experience?
After the mini ECU "learns" my driving style does it change performance parameters. How drastic a change could there be?
Can it affect gas millage? Throttle tip in? and so on.
I guess finally I want to know is a reset going to be a noticeable difference that makes it worthwhile.
Last edited by Rob'sDad; Nov 6, 2019 at 08:32 PM. Reason: Added quotation marks around the first sentence
Old Nov 7, 2019 | 10:24 AM
Derek86's Avatar
Derek86
I believe the car will learn any new mods by default after enough time, the reset just forces it to adjust immediately by wiping its memory.
I've only done it twice, and both were more to wipe a car that hadn't been running correctly. Once when the intake tube to the S/C failed and once when the crank pulley failed. I figured I didn't need that last couple hundred miles of not running right to be logged into the ECU learning.
Old Nov 7, 2019 | 10:28 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Resets of adaptations on my cars were always short lived. If you have an underlying problems, they will show themselves quickly.
Old Nov 7, 2019 | 11:17 AM
Rob'sDad's Avatar
Rob'sDad
Thanks for your input guys.
I don't want to fix a problem, but I'm more interested in how this "learning" process affects the performance and driving characteristics of the car.
Old Nov 9, 2019 | 01:39 PM
OCR's Avatar
OCR
Like "most" all ECM's the "learning" term is somewhat of a misnomer.
The hex cells (given map picture) CANNOT "change" themselves. All the so called learning is, the computer has the option built in to move the starting point, up or down the overall map. Hex cells are not actually changed, the used cells are just moved, up or down to another line, possibly side to side depending on the rpm, if changed or not.
The ONLY way to actually "change" a given map (hex cells) is to go in and...make a hex cell value change, richer or leaner, higher timing, lower timing, etc. This is done by basically a computer "hack". I've done this on a coupla cars and four different motorcycles.
Mike
Old Nov 10, 2019 | 07:04 PM
Rob'sDad's Avatar
Rob'sDad
Mike
Hi Mike
Does this equate to the mapping making the motor run more efficiently with the new parameters presented to it with a mod? (efficiency could mean faster)
Thanks, Bob
BroBeanz
Feb 25, 2016 10:11 AM
witecpa4u
R55 :: Clubman Talk (2008+)
Aug 25, 2013 08:15 PM
N Tief
11
Mar 9, 2013 08:58 PM
mini_wolf
Mar 31, 2011 09:28 AM
ScuderiaMini
Mar 22, 2006 10:59 PM
