JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Another JCW for your Enjoyment
Old Jun 15, 2025 | 05:37 PM
  #26
Krunch2020's Avatar
Krunch2020
String Alignment
I just did a $30 string alignment. First I checked the Bentley Manual which said to put 150lbs in each front seat and 30lbs in the boot plus a full tank of gas before starting.
After a trip to the big box store to get 6 50lb bags of fence post concrete (I’m about to build a retaining wall) I put a large plastic sheet in the interior and carefully placed the bags on the front seats. I put some dumbbells in the boot with a small toolbox since the tank is only 1/2 full.
The camber was seriously excessive and had to be adjusted to the minimum to get even close to 1.5 degrees. Then I set up the parallel fishing lines and checked the toe-in. The right side was amazingly perfect. 1/32 of toe-in. The left side was way off but easily adjusted with the car on the garage floor and multiple folded garbage bags under the tires. It only took about an hour after rounding up the stuff.
Test drive tomorrow! Kurt
Old Jun 16, 2025 | 10:51 AM
  #27
Krunch2020's Avatar
Krunch2020
Project Completed
The test drive was great! Suspension is nice and quiet and seems more balanced with the 20mm Whiteline rear sway bar. I’ll get the fender liners back in and call it good!
Chili Red by a Redwood Tree
JCW Rear End
JCW Rear End
Old Jun 16, 2025 | 11:39 AM
  #28
mooser's Avatar
mooser
Nice Car
A383Wing
Sep 22, 2024 10:31 AM
TheMallardDuck
Mar 5, 2020 01:06 PM
ken o
Nov 13, 2012 12:26 PM
NavyMini
Mar 9, 2008 08:53 AM
