JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
O2 Sensor Elbow and CEL fix
Old Jan 13, 2022 | 11:02 AM
nevets54's Avatar
nevets54
Anybody have insight or ever use one of these? There are quite a few all over Ebay.
https://www.ebay.com/itm/203746459419
I installed Milltek Header and sport Cat and aside from getting a CEL code, the tip of sensor hits the tunnel wall, really just barely touching. I started looking for an angle adapter then found this. I assume w my sport cat it will probably throw a code regardless. Yesterday I cleared code then it returned. Also...is there an easy way to test the sensor itself? should I just replace it? Should I replace both upstream and downstream?
Any/all advice is appreciated...
Old Jan 19, 2022 | 10:58 AM
nd-photo.nl's Avatar
nd-photo.nl
Not specifically on the Mini, but I have used a O2 spacer with success before on my Seat Leon 1.8T when I fitted a decat downpipe.
Old Oct 13, 2022 | 05:12 AM
ilhaji's Avatar
ilhaji
I installed the right angle on mine but I got the p0137 (low voltage) so I’m not sure if it’s the same issue that can be fixed with straight spacer.
Tutuapp 9Apps Showbox
Old Sep 9, 2023 | 03:04 PM
MINI_42's Avatar
MINI_42
Did you get it sorted out?
I replaced the header on mine with a Scorpion and inadvertently deleted the first cat. It runs well, but the CEL P2096 was a common sighting until I replaced the O2 sensors with NTK ones. They did not solve the issue until I installed the 90 degree adapters. Occasionally the light would reappear and the last time it did, I tightened up the sensors and adapters a little more, cleared the code and it hasn't been seen again after several thousand miles.
northbarts
Feb 27, 2013 06:11 PM
tiny s
Jun 6, 2012 01:17 PM
Evowned
Feb 24, 2009 05:40 PM
jrprich
Sep 6, 2008 06:46 PM
brianthenewguy
Jul 19, 2008 08:12 PM
