R50/53 Help with computer code p0130
Old Jul 15, 2008 | 05:59 PM
brianthenewguy's Avatar
brianthenewguy
So i recently had the check engine light go on. Took it into Pep Boys had them pull the code for me. It gave me a:
po130 o2 sensor circuit malfunction (Bank 1 sensor 1)
So I am going to replace the o2 sensor. But in buying one should I be getting the one before the cat or after the cat?
Old Jul 16, 2008 | 07:04 PM
emagers's Avatar
emagers
Dear Brianthenewguy,
Sure that is the pre-cat. Recommend changing the O2 sensors at 100K per manual, so depends on your mileage and finances. They are pricey at about $150.00 from advance auto (don't know about Prep-Boys). Word of "free advice" from a problem lasting over a year, buy only Bosch brand, had a problem from Minicarparts.net, cost was about half, looked identical and didn't work right. Good luck.
Old Jul 17, 2008 | 05:14 AM
brianthenewguy
Thanks, Was it the Bank1 or sensor one that lead you to believe it was pre-cat? Thanks for the info though.
Old Jul 17, 2008 | 05:45 AM
Scott508's Avatar
Scott508
is there not a recall on this 02 problem?
call your dealer. it should be replaced free.
Old Jul 18, 2008 | 03:31 PM
emagers's Avatar
emagers
I had been told from someone from NAM that this was the pre-cat sensor.
Old Jul 18, 2008 | 05:14 PM
cwoodwar's Avatar
cwoodwar
It is the pre cat. I just replaced mine today. Got it from pep boy's $170.00, auto zone wanted 200.00. it was a bosch o2 sensor.
Old Jul 19, 2008 | 08:26 AM
gohwkis's Avatar
gohwkis
Help with replacing o2 sensor
Can anyone help me??? I need diagrams and tips on how to change the 02 sensor. I think it is the pre catalytic one based on the earlier replies since I am getting P0130 code. I am also getting P0302 which is the misfre on cylinder 2 which I hope is from the o2 sensor issue?
Old Jul 19, 2008 | 01:16 PM
Ancient Mariner's Avatar
Ancient Mariner
Go to realoem.com and follow the leads. You should see a pretty good diagram of what you're looking for. Might need an O2 sensor socket (slotted to clear the wires), and remember: only change it when the car is stone cold. Hot exhaust, stripped threads, burnt digits, etc. if not.
Oh, heck, go here:
http://www.realoem.com/bmw/showparts...75&hg=18&fg=10
it's an '04 non-S, but they are all pretty similar. You didn't give any info on yours, so I just closed my eyes
and guessed.
Old Jul 19, 2008 | 08:12 PM
metaltech's Avatar
metaltech
Oh, heck, go here:
and guessed.
Ancient one, thank you for the link. This is fantastic!!!
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
sirfrank
Sep 11, 2015 01:36 PM
Gen1Parts
Sep 7, 2015 03:50 PM
NHcountryman
Sep 6, 2015 11:01 PM
