JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
R58 JCW whine\screech under under load
Old Aug 29, 2021 | 01:47 PM
moscoupe92's Avatar
moscoupe92
Hi everyone,
I have a n18 jcw coupe.
Just changed turbocharger, alternator, water pump, water pulley, friction wheel, crank pulley, and tried 2 belts..
This bloody whine/screech is coming from the right side (i think).
Its only noticeable when im in gear.
Its not present when the car is in neutral ???
What could cause this?
Didnt have this Sound before i changed everything.
Link to the video:
Old Aug 31, 2021 | 07:56 AM
thefarside's Avatar
thefarside
Best guess is the turbo plumbing is messed up. No codes?
Old Aug 31, 2021 | 08:34 AM
moscoupe92's Avatar
moscoupe92
nope, no codes.
Car is pulling perfectly!
Old Sep 13, 2021 | 11:45 AM
moscoupe92's Avatar
moscoupe92
Anyone?? Any help would be appreciated..
Old Sep 13, 2021 | 06:28 PM
NeonLed's Avatar
NeonLed
Noise maker not plumped right maybe?
Old Nov 3, 2021 | 12:40 AM
moscoupe92's Avatar
moscoupe92
as far as i know the n18 engine doesnt have a noise maker ??
Old Nov 3, 2021 | 12:55 AM
moscoupe92's Avatar
moscoupe92
anyone ? :(
i changed all the pulleys again, the noise still exists!
Old Nov 3, 2021 | 03:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
As I mentioned in your other thread, sounds like it’s turbo intake noise, which would be normal for a larger turbo and aftermarket intake.
Old Nov 3, 2021 | 07:15 AM
moscoupe92's Avatar
moscoupe92
hi mate,
thanks for replying.
i didnt have that noise with the old turbo…
im also running a catless downpipe + cooper S centerpipe.
Old Nov 3, 2021 | 07:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What was the reason for changing the turbo? If the new one is actually working now, it will pull more air. Open intakes let all the suction noises out, too. If you had an intake leak, you would have a code.
Seriously, sounds normal to me. Please list all modifications, and a picture of your engine bay. Go grab a video of a full throttle pull.
Old Nov 22, 2021 | 01:09 AM
moscoupe92's Avatar
moscoupe92
Hi mate,
You were absolutely right! It's coming from the air filter cone. I noticed it during a cold start the suction noise was coming from there.
I'm running a scorpion catless downpipe + cooper S N14 centrepipe.
Turbo had 110.000 miles on it and little bit of turbine play.
Is this normal? Why is only audible under light load an not under full throttle ?
Cheers
Old Nov 22, 2021 | 05:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Under full throttle it likely gets drowned out by the other engine and exhaust noises.
witecpa4u
R55 :: Clubman Talk (2008+)
Aug 25, 2013 08:15 PM
joltfreak
Classic Mini Talk
Mar 17, 2009 04:09 PM
