JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
R52 jcw rear badge location
Old Aug 29, 2020 | 04:19 PM
Kitchenboy's Avatar
Kitchenboy
When I bought my 08 R52 JCW the rear JCW badge was missing so I finally bit the bullet and bought one. Can any of you that have a R52 post a pic of the rear hatch so I make sure I get the new badge in the right location. This is the only pic I could find and I want to make sure its correct. Thanks
Old Aug 29, 2020 | 04:37 PM
RB-MINI's Avatar
RB-MINI
From the R53 JCW 210 kit instructions. I wouldn’t think it’s any different on the convertible. Note the reminder that the alignment might need adjusting if the Cooper S emblem is on the hatch.
Old Aug 29, 2020 | 05:00 PM
Kitchenboy's Avatar
Kitchenboy
So basically centered left to right and if the cooper s is on the right your supposed to match the height of the JCW badge with that.
Kitchenboy's Avatar
Kitchenboy
Is benzine just rubbing alcohol.
Old Aug 29, 2020 | 08:56 PM
Fly'n Brick's Avatar
Fly'n Brick
It's a petroleum byproduct. Alcohol is produced by fermentation of fruits or vegetables.
Old Aug 29, 2020 | 09:02 PM
Kitchenboy's Avatar
Kitchenboy
Well since I dont have any Benzine what should I clean the car with before sticking the badge on.
Old Aug 29, 2020 | 11:32 PM
Fly'n Brick
Any auto parts shop will have what you want. Meguiar's Gold Class is good stuff as are their other products.
More than likely a total paint detail job is in order.
Old Aug 30, 2020 | 12:36 AM
RB-MINI's Avatar
RB-MINI
I would wash the car, or just the back, using Dawn dishwashing soap which will clean and remove most waxes from the paint, dry, stick the badge on, then re-wax. If the Dawn doesn’t remove the wax or sealant, then you might have to use something from an auto body supply shop.
Also, the badge will stick better if the body and adhesive tape are warm.
Old Aug 30, 2020 | 06:09 AM
Kitchenboy's Avatar
Kitchenboy
My issue is the car was just fully detailed and ceramic coated like 5 months ago so I dont want to start stripping that off. Maybe I'll just tape off the area where the badge is going and give it a good cleaning and hope for the best.
Old Sep 15, 2020 | 06:34 PM
Eurothrasher's Avatar
Eurothrasher
wipe the badge area location with rubbing alcohol.
apply and drive
Old Sep 15, 2020 | 06:48 PM
Kitchenboy's Avatar
Kitchenboy
That's what I did.
Kitchenboy
Aug 27, 2020 03:51 PM
Peppe
18
Apr 9, 2020 09:26 AM
Kitchenboy
Feb 18, 2020 08:40 AM
A383Wing
Sep 13, 2018 08:41 PM
Peppe
Jul 3, 2017 06:43 PM
