JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
N18 Engine Serpentine Belt........
Old May 1, 2020 | 06:56 PM
dube53's Avatar
dube53
How do you check the serpentine belt for wear and at what intervals is it recommended to service?
Old May 2, 2020 | 03:44 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
How many miles on the car?
Checking the belt is a visual inspection. Look at the belt and check for signs of cracking or fraying. If you see either of those, it needs to be replaced.
Old May 5, 2020 | 05:28 PM
Cracks and then on the back side of the belt you will get these little high spots that wear. Thats when i know its time. Some people check with the tool: https://www.ecstuning.com/b-conti-te...ntitester~con/
Old May 10, 2020 | 05:08 PM
dube53's Avatar
dube53
Where do you have easy access to check it other than removing the inner fender? It has been replaced 20k miles ago.
Old May 10, 2020 | 05:24 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We recommend it every 60k or anytime you see cracks in the belt.
We have a wrench that makes the job super easy to replace.
https://www.waymotorworks.com/belt-t...8-r60-r61.html
Old May 11, 2020 | 10:06 PM
dube53's Avatar
dube53
Thanks for the info about recommended maintenance. I already bought both wrenches and also an OEM belt but I think I will wait another 30K to service that item if I even keep the Mini as long.
Old May 12, 2020 | 06:02 AM
Should be fine with that mileage i change mine at about 50K. From the bottom of the car you can see the belt and use the special tool to change the belt from the bottom if needed. Remove the little splash guard. Or open up the under the fender line to see more.
https://www.northamericanmotoring.co...ne-belt-431269
hamptup
May 24, 2016 04:53 PM
vodka
Feb 24, 2011 02:37 AM
seatosky
Jan 25, 2008 04:03 PM
