JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Oil Leak Cause?
Old Mar 22, 2020 | 10:08 AM
prmspen's Avatar
prmspen
Oil Leak Cause?
My 2011 JCW is leaking oil from under the front passenger side. Pretty much right under the dipstick (maybe a little behind it). Oil level doesn't seem to be dropping at all, and it's not a huge leak (couple of drops per night). Any ideas on the source?
Old Mar 22, 2020 | 12:08 PM
user 7389739's Avatar
user 7389739
Built in feature of most BMW products to let you know you still have oil in the engine. Nothing to worry about, unless it stops...
First guess: the dipstick O-ring.
Old Mar 22, 2020 | 01:19 PM
oldbrokenwind's Avatar
oldbrokenwind
If you have the time, tools, and patience, pull the wheel and fender liner off to check the engine front end. Lotsa seals and hardware to leak from located there. Otherwise take it to a Mini indi shop with a lift. Maybe they can find it for you.
Old Mar 26, 2020 | 08:14 AM
bugeye1031's Avatar
bugeye1031
Moderator
Prime offenders on that end that I know of: crank seal, oil pan, tensioner, valve cover. I agree with oldbrokenwind....inspect. I'd start at the top with the tensioner and valve cover because they can leak and it can look like the crank seal and/or oil pan if you look at it from the bottom. It's probably not the valve cover....the tensioner is more common and not too hard to check.
Old Mar 31, 2020 | 07:09 AM
+1 Oil pan, crank seal on the passenger side. Bugeye hit all the ones i would check.
Old May 26, 2020 | 11:27 AM
harkine's Avatar
harkine
I noticed that I have the same issue. It is not the valve cover. I looked around the oil pan and did tighten the screws a little bit. I will have to check the tensioner next.
Old May 26, 2020 | 12:47 PM
prmspen's Avatar
prmspen
Mine turned out to be the oil filter mount and gasket. Got that fixed and the leak is gone. It's tricky to get to, but you might want to check that out.
Old May 28, 2020 | 06:53 PM
cpmetz's Avatar
cpmetz
OP mentioned passenger side - if someone is taking bets, I'm in for the crank seal behind the crank pulley.
prmspen
Mar 25, 2020 06:53 AM
Sleepie
R60/R61 Stock Problems/Issues
Nov 26, 2014 08:19 PM
Shoe Coupe
Jan 21, 2013 11:47 PM
Myke@RPI
Mar 19, 2010 08:07 PM
