JCW end links
Old Mar 13, 2020 | 07:10 AM
madmix's Avatar
madmix
end links
I put a 25MM Sway on the JCW. I have heard two schools of thought on the end links. some say should be replace because not strong enough, others say not a problem. Thoughts?
Old Mar 13, 2020 | 08:00 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've installed so many of our WMW 25mm bars on the F56 and 90% of them have the stock links and I haven't seen any break yet so I'd just stock with the stock ones for now.
But when or if you do want to upgrade these are the ones we have been using
https://www.waymotorworks.com/nm-eng...5-f56-f57.html
Old Mar 13, 2020 | 08:29 AM
Warren2185's Avatar
Warren2185
I kept the stock end links on mine. I'm not convinced that just because they appear less substantial than the looks of the aftermarket ones, that the stock have any strength issues at all.
Old Mar 13, 2020 | 09:17 AM
madmix's Avatar
madmix
Great good to hear the way motor works sway is beefy so wanted to make sure thanks everyone
Old Mar 13, 2020 | 10:30 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Personally, you are going through all that effort for the bars, just change them. It will add about 10 mins to your install
Old Mar 13, 2020 | 10:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Change them, yes. But no need to spend big on aftermarket links when the OEM work just fine.
Old Mar 13, 2020 | 03:19 PM
rtowell's Avatar
rtowell
On the NM Engineering site, they specifically recommend using their adjustable end links (http://www.nm-eng.com/345/0/0/3224/n...-bar-25mm.html). They may be overkill, but at least I don't have to worry about them.
Old Mar 14, 2020 | 07:55 AM
MikeMJCW's Avatar
MikeMJCW
I have factory F/&R end links (eibachs sway's) for about 8k miles with no issue until recently it developed knocking (in front) only during "tight parking" maneuvers, steering wheel at both extremes .
The front bar contacts the lower control arms. As for the rear links I thought I read somewhere that the NM links contact the rear control arms?
Not trying to hijack your thread but I'm thinking of getting adjustable (shorter) front links if anyone has suggestions for model/brand etc.?
Old Mar 16, 2020 | 05:34 PM
J_L's Avatar
J_L
I got these. Solid quality, $70.
https://godspeedproject.com/front-sw...10mm-bolt.html
Old Mar 29, 2020 | 04:29 PM
MikeMJCW's Avatar
MikeMJCW
Just installed the Godspeed (BTW a character from The Flash) front swaybar end links. Set them to 310mm (10mm shorter than stock) we'll see how they work out tomorrow.
Old Mar 30, 2020 | 10:37 PM
rbm416's Avatar
rbm416
If you are running at stock right height, then they are not needed. If you have lowered the suspension, then yes get the adjustable end links so you can dial out any pre-load introduced by lowering.
Old Mar 31, 2020 | 06:04 AM
MikeMJCW's Avatar
MikeMJCW
My car is only lowered 10mm but after about a year of use the front sway bar made contact with the lower tie rod/control arms during tight turning (U-turns/parking). Tried it out yesterday and so far so good.
Old Mar 31, 2020 | 11:26 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
So GodSpeed sells adjustable front sway bar end links??? I need them!!!
Old Mar 31, 2020 | 11:30 AM
MikeMJCW's Avatar
MikeMJCW
J_L sent me the link, then I searched Ebay $58.
Old Apr 1, 2020 | 08:45 AM
TVPostSound's Avatar
TVPostSound
"preload" is NOT introduced by lowering.
Only if the aftermarket bar is not bent perfectly.
Old Apr 1, 2020 | 10:50 AM
madmix's Avatar
madmix
Thanks for all of the input very helpful. I will stick with stock for now since I would rather spend money somewhere else. Only "complaint" is the squeak, but just to lazy to fix so far.
Old Apr 2, 2020 | 03:50 PM
rbm416's Avatar
rbm416
Lowering the car loads up the sway bar. Adjustable end links help take that load off when the car is lowered allowing you to put it back in a neutral state and not affect the ride of the car.
https://www.northamericanmotoring.co...-up-front.html
Old Apr 2, 2020 | 04:14 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Nope, it only loads the sway bar if you lower each side a different amount. If you lower both sides of the car the same amount, the sway bar end relocate the same amount, and no preload. The only real reason for adjustable end links is to accommodate any clearance issues from lowering.
Old Apr 3, 2020 | 04:16 AM
Darbys2019MiniJCW
Yes and No...
You want to keep the sway bar in it's normal location for clearance reasons so adjustable end links are a good thing
If you lower your car based on corner weights, the end links can be adjusted individually to either keep the suspension as neutral as possible OR
You can preload the sway bar based on track condition/design
Remember, we drive "minis" and design space is of the essence
Old Apr 3, 2020 | 04:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Originally Posted by Darbys2019MiniJCW
Yes and No...
I agree with what you are saying, but also I’d be willing to bet 98% of the members on this forum that install coil overs are NOT adjusting corner weights on their Mini. I won’t even include the members just installing springs.
In this instance, the OP claims to have only installed a rear sway bar, and said nothing about installing coil overs or even springs. So, in his case, I would recommend staying with OEM end links.
Old Apr 3, 2020 | 07:43 AM
MikeMJCW's Avatar
MikeMJCW
I just ordered the NM rear links after confirming that the rear bar is not horizontal (sits slightly high). To my surprise Mini sells the JCW coilovers (10mm - 30mm drop) yet did not address this "weak" long link issue.There was guy here that had H&R sways he thought were to stiff, don't remember if his car was lowered. I think the shorter links would have helped?
IMO No harm in trying the stock links but apparently even with just a 10mm drop the shorter links are warranted.
Old Apr 3, 2020 | 11:09 PM
madmix's Avatar
madmix
I do have my Mini Lowered with HR springs.
Scooter24
Apr 5, 2017 09:28 AM
Mini_Touge
Suspension
Dec 12, 2015 04:02 PM
british RACING green
Suspension
Oct 2, 2009 09:06 AM
tommy_zito
Suspension
Oct 31, 2008 05:09 PM
RedSkunk
Suspension
28
Apr 17, 2008 07:57 PM
