JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Boost Pressure Deviation 2885 problem found.
Old Jan 4, 2020 | 08:25 AM
Etz's Avatar
Etz
After new valve cover, water pump, coolant pipe, thermostat housing, vacuum tank, and vacuum lines I started getting code 2885. Checked as much as I could. Threw in the towel and took it to a shop. They said bad turbo. I decide to do some more checking. Removed the O2 sensor (easy) and discovered this. Waste gate completely gone. Worth just replacing the waste gate? $60 for parts or replace everything?
Old Jan 4, 2020 | 09:34 AM
MrGrumpy's Avatar
MrGrumpy
If you can get a new wastegate for $60 I’d do it. It’s better than the cost of a whole new turbo.....unless you are looking to upgrade. Another option is just replacing the exhaust housing side (hot side) of the turbo, it will have a new wastegate. JMTC (JMTurboCoopers) has them. When mine went I upgraded the turbo, but you will probably want a tune if you do.
Old Jan 6, 2020 | 05:56 PM
minidd99's Avatar
minidd99
As far as I know you can't just buy the waste gate.
You will have to get the exhaust housing side.
Old Jan 24, 2020 | 01:27 PM
bugeye1031's Avatar
bugeye1031
Moderator
Agree with MrGrumpy When I got 2885, it was my wastegate as well. I decided to replace the turbo with a larger JMTC turbo after considering the JMTC exhaust housing.
Last edited by bugeye1031; Jan 24, 2020 at 01:27 PM. Reason: forgot to mention MrGrumpy!
Old Mar 21, 2020 | 07:40 AM
bugeye1031's Avatar
bugeye1031
Moderator
Status?
Old Mar 30, 2020 | 08:02 AM
Rich B.'s Avatar
Rich B.
Where do you suppose the waste gate went?
Old May 6, 2020 | 01:18 PM
bugeye1031's Avatar
bugeye1031
Moderator
I'll bet its just lodged in the cat.
goj210
Apr 24, 2017 01:06 PM
JohnY
Nov 20, 2014 07:54 AM
Theo_207RC
R60/R61 Stock Problems/Issues
Sep 26, 2012 05:36 AM
5810
Nov 4, 2010 04:47 PM
chuntington101
Dec 30, 2008 05:08 AM
