JCW F56 belt line removal ?
Old Oct 15, 2017 | 07:23 AM
SFMCS's Avatar
SFMCS
I am prepping my '15 S to wrap it (GP 3 concept inspired) and need to remove the belt line. I checked the manuals and tested some pieces. The hood and front quarter panels (scuttle panel) come off easily. The door may have a screw close to the handle side and does not appear to be a problem. What I cannot find is the trim on the rear/side windows. On some videos, it appears to be glued on. The manual on the website lists an adhesive. Any help will be appreciated.
BTW, the mirrors come off easily. In folded position, remove two plugs on base and use an Allen wrench. The door handle appears to be easily removed, there is a plug in the side on the door that lets access to the holding screw, and like most cars, once removed, the handle slides off (towards the screw hole).
Thanks.
2015 MCS
White silver/Aspen white (soon to be metallic black)
NM sway bars/cold air
JCW int/ext
JCW tuned
Pirelli P zero 215
Montegi MR 32 wheels
Old May 13, 2020 | 06:50 PM
Justin Maulkeet's Avatar
Justin Maulkeet
I am working on a 2015 at the moment doing a satin wrap. Did you ever figure out how to remove the beltline. As you stated hood and scuttle no problem. I dont want to break them on the doors back and cant figure out how to remove them.
Old May 15, 2020 | 01:35 PM
curlywurly's Avatar
curlywurly
Originally Posted by SFMCS
need to remove the belt line. trim on the rear/side windows
Chap from the UK f56 board called tweedbean did this to his whitesilver - and hes a prolific instagrammer. fire a note to him maybe on 'insta'
on the f56 board:
https://www.minif56.com/threads/twee...-2#post-828019
on Insta he is 'tweedbean'
Old May 15, 2020 | 02:04 PM
SFMCS's Avatar
SFMCS
Yes, a couple of times. All of the instructions are on newtis.com It is under the body components section.
Old May 15, 2020 | 02:07 PM
SFMCS's Avatar
SFMCS
Sorry about that. It is "newtis.info". Pretty complete manual.
onionjello
How to
39
Apr 4, 2025 10:47 PM
Irishmic
Apr 16, 2014 08:49 PM
duster52
Nov 10, 2011 06:59 PM
MarioKart
May 14, 2007 02:33 PM
richyc
Sep 7, 2003 05:07 PM
