JCW Shifter Recommendations
Old Jul 26, 2017 | 03:14 AM
2017JCWerks's Avatar
2017JCWerks
Car is a 2017 JCW. The stock shifter isn't bad, but it's more sloppy than I like. I would like to tighten it up some and reduce the throw. Any recommendations?
Old Jul 26, 2017 | 08:48 AM
02fanatic's Avatar
02fanatic
Someone will likely mention the Craven Shifter (I think that's what it's called), but I'd prefer to keep the stock shift ****/shaft but employ a short shift kit (similar to what you can do in BMW's). My only real gripe about the F56 JCW is the shifter & clutch pedal feel are to "soft". I am getting used to mine, but I have found myself looking for 4th gear when downshifting too many times!...grrrr. It needs to be "easy" to find!
Old Jul 26, 2017 | 11:15 AM
al the mini man's Avatar
al the mini man
Have a look at the Forge short shift kit,i have one on my F56 and i am very pleased with it.
Old Jul 26, 2017 | 02:30 PM
2017JCWerks
I feel exactly like you do. I like the shifter, just not the throws.
Old Jul 26, 2017 | 07:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I like the Craven as it has the best feel even when you don't have it adjusted real short. Also allows you to adjust anytime you want.
https://www.waymotorworks.com/craven...ifter-f56.html
Old Jul 26, 2017 | 07:34 PM
vetsvette's Avatar
vetsvette
Moderator
Wait for it.........
Yup. Cravenspeed adjustable short shifter. It can be used with the stock **** or the **** of your choice. I had one in my R56 and liked it so much that it was one of my first mods on my F56. For myself, the combination of the CS shifter, CS Pro clip, and S4S shift **** are a perfect combination. YMMV
Old Jul 27, 2017 | 05:11 AM
1chaos52's Avatar
1chaos52
For stock height etc, I really like the NM adaptor which I have in my car. Makes a nice difference in the shifting length while keeping the shifter at a nice height and not making it too stiff. I also put in the Cravenspeed piece that goes around the ball when I did mine and that helped with some of the slack as well.
Old Jul 27, 2017 | 10:59 PM
Clutch Wotan's Avatar
Clutch Wotan
shop.cae-racing.de
Old Jul 28, 2017 | 09:14 AM
vetsvette's Avatar
vetsvette
Moderator
Originally Posted by Clutch Wotan
shop.cae-racing.de
That's a great looking shifter, but I don't like that it requires heavy modification to the console and that you have to move some switches. I could see it for a "track only" car though.
Old Jul 28, 2017 | 09:59 AM
JPMM's Avatar
JPMM
keep an eye out for one of these if they decide to make it fit your car
http://www.tyrolsport.com/engine/dri...-r56-platform/
Old Jul 28, 2017 | 11:23 AM
vetsvette's Avatar
vetsvette
Moderator
Forge has had one out for a while.
https://www.forgemotorsport.com/Shor...uct--1368.html
Old Jul 28, 2017 | 11:49 AM
02fanatic's Avatar
02fanatic
I agree....that was my thought exactly! That shifter looks like it belongs in a serious track or race car, not a street machine.
Old Jul 30, 2017 | 01:47 AM
Clutch Wotan
i have incorporated that very smooth into my R56, but i agree that it is not a easy DIY solution, however placing the shifting *** close to the steering wheel together with minimum of effort, you shift out of you hand-angle, and basicly no miss shifts, its for me a must. The new F56 solution from CAE is a Golf MK1 basis,which i consider as ugly, we will modify a other unit from them, and remove the armrest and and some other parts ( 8 kilos less) and cover the middle section with a tradional carpet. This is certainly not only good for track but also underline the look of a classic coffee racer.
Old Jul 30, 2017 | 10:27 AM
pianoman011's Avatar
pianoman011
i removed my NM Engineering short shifter and installed the Craven Speed Adjustable short shifter along with their shift **** and shifter clip. There is a world of difference. Much reduced sport shifting somewhat like a Miata, and a better overall feel. I use it in its shortest position and will never go back to stock. I think it is one of the best mods that you can do to your manual F56.
Old Jul 31, 2017 | 01:47 AM
Clutch Wotan
https://www.northamericanmotoring.co...1&d=1501490714
https://www.northamericanmotoring.com/g/picture/3810011
