JCW Installing JCW Pro Spoiler Extensions
Old Jun 4, 2017 | 05:30 PM
jessetaylor's Avatar
jessetaylor
Thumbs up Installing JCW Pro Spoiler Extensions
Is there a guide to lining up and properly sticking the extensions on the spoiler?
Thanks!
Old Jun 4, 2017 | 07:03 PM
TheGeekGuy's Avatar
TheGeekGuy
Not really. Here is a thread on NAM with an image of the fitted component. Might give you an idea about placement:
https://www.northamericanmotoring.co...-diffuser.html
Old Jun 4, 2017 | 07:51 PM
vetsvette's Avatar
vetsvette
Moderator
The extensions come with a template for mounting. I eyeballed mine.
Old Jun 5, 2017 | 05:51 AM
jessetaylor
Thanks, I'll update with pics once I get the car today. Only took 3.5 months.
Old Jun 5, 2017 | 06:11 AM
vetsvette's Avatar
vetsvette
Moderator
Congrats Dude! Look forward to seeing pictures.
Some quick pics of my extensions......
EDIT: Sorry about the lack of pictures. Photobucket is trying to extort users to pay $400 a year to continue 3rd party hosting. That's not gonna happen!
Old Jun 5, 2017 | 06:50 AM
kfmuller's Avatar
kfmuller
I tried eyeballing them after I found the template to be difficult to deal with. I finally taped off the area with painter's tape to make sure I got them on correctly.
Mind you - this was after I put them on wrong the first time. The 3M adhesive tape on the bottoms adheres instantly. I had to use a blow dryer to heat them up, and some fishing line to remove them. I took off the original tape that was ruined, put on some more 3M auto adhesive tape, and started over to make sure I got them aligned correctly the second time. So take your time, tape off where you want to put them, and realize if you screw up, it's not the end of the world.
Old Jun 5, 2017 | 01:36 PM
hadjiikong's Avatar
hadjiikong
What color did you use for the red? I tried to find a red pair but no luck so picked up a pair of black ones to paint. Just not sure what color red matches.
Old Jun 5, 2017 | 05:55 PM
vetsvette's Avatar
vetsvette
Moderator
They only come in black. I had my body guy paint them "Chili Red". Paint code is 851 IIRC.
Edit: http://paintref.com/cgi-bin/colorcod...or=Chili%20Red
Old Jun 7, 2017 | 12:23 PM
jessetaylor
Thanks for the help guys. Pics and story is in new thread "After 4 Months new JCW finally here"
Old Jun 7, 2017 | 01:43 PM
02fanatic's Avatar
02fanatic
How much did your paint guy charge you? Thanks!
Old Jun 7, 2017 | 04:25 PM
vetsvette's Avatar
vetsvette
Moderator
I couldn't tell you. I had the roof, hood scoop, grill surround painted at the same time. Also had the custom stripes done at the same time. Didn't get an itemized invoice.
Old Jun 9, 2017 | 08:54 AM
Wow that looks good painted. 99% of the time i see them in black.
Old Jun 9, 2017 | 09:17 PM
vetsvette's Avatar
vetsvette
Moderator
Thanks. I planned to have them painted from the get go.
Old Jul 1, 2017 | 10:37 AM
Hoopty's Avatar
Hoopty
Diffuser, Splitter, Extension Instructions
Thanks!
Don't know why these are not included with the kit......but gluing the rear diffused is the only way to get it fit properly. Here are the instructions for the extensions, splitters and diffuser.
Enjoy!
Hoopty
Old Jul 3, 2017 | 07:29 AM
Thanks for posting those instructions up I was just going to post that.
JCW Pro Rear Diffuser Kit W/O PDC F56 F57 51192339047
https://www.ecstuning.com/b-genuine-...c/51192339047/
JCW Pro Rear Diffuser Kit W/ PDC F56 F57 51192339046
https://www.ecstuning.com/b-genuine-...c/51192339046/
Old Aug 28, 2017 | 08:29 PM
djtomy's Avatar
djtomy
I put mine as close to the center as I could
Old Sep 10, 2019 | 05:44 AM
Eddie07S's Avatar
Eddie07S
I just purchased the JCW Pro rear spoiler extensions for my 2019 JCW. Thanks for posting the instructions and great pictures. I plan to get the rear diffuser kit too, so this will be a great help.
Old Oct 15, 2019 | 10:51 PM
Alpha Motoring's Avatar
Alpha Motoring
If anyone is considering the extension or diffuser, you should really consider painting the extension and the outside of the diffuser.
The plastic they use looks almost like bare primer
Old Oct 24, 2019 | 05:04 PM
Eddie07S's Avatar
Eddie07S
A while back I bought the JCW Pro winglets for the rear spoiler and have finally gotten a chance to install them. It is quite easy and probably doesn’t need a DIY, but I thought I would do one anyway.
I decided to leave the winglets the flat black that they came as. My car is black and I thought the flat black went well with the rest of the flat black pieces. Others had theirs painted to match the color of their cars. Either is an option.
Not sure why I was surprised at how small they are, but I was when I picked them up. I also bought the installation kind kit that consists of a paint cleaner and the BMW adhesive (not worth it, more to come about that).
BMW/MINI mounting kit and JCW Pro rear spoiler extensions
The winglets package includes a template and no instructions (the ones posted above are really good). I know that some people installed these by eye and did just fine. The template really simplified the installation for me, especially considering how tenacious the mounting tape is. It was easy to just line up the parts with the template and then press them down on the spoiler. Not sure how easy this would have been to do if there was the adhesive on the underside of the winglet.
I took a close look at the cleaner. My nose tells me this is just naphtha that you can buy at a hardware store, for much less money. A test on the car finish showed no damage so I went a head with using it to clean off any wax and whatnot. As for the MINI/BMW adhesive, I decided to not use that either. The underside of the winglets has 2 spots of exposed plastic where this glue is to be applied. This would likely take only about a half ounce of adhesive, whereas the kit probably contains 6 to 8 oz of the stuff. The adhesive is packaged in what can only be described as a plastic sausage wrap. I figured once opened the rests was waste. I’ll save that for the JCW Pro diffuser I plan to get.
Instead of using the adhesive, I used a second layer of automotive trim tape that I applied over the exiting trim tape on the winglets. I felt that slight additional height of the second layer of tape would ensure a uniform stick to the spoiler.
Winglet with second layer of trim tape. Used an Exacto knife to trim the tape once it was in place.
[size=3]As the instructions say, cut the template out along the dotted line. But my suggestion is to not cut out the center section as it shows. Instead, from the edge of the paper, just make a 2”-3” cut along the dotted line to let it flex a little and fit the curvature of the spoiler. I found this retains some stiffness of the paper through its length, making it easier to fit to the spoiler.[/size]
I used blue painter’s tape to attach the template to the spoiler. I took care to get the lines on the template lined up with the leading (most forward) edge of the spoiler. There are some sharpe curve lines on the template outline that match the edge of the spoiler, which make for good reference points. The leading edge of the template matches the edge of the roofline.
Winglets in place with the template.
[size=3]From there, the rest is easy. Line the winglets up with the template and press them into place. I let them sit for 24 hr to ensure good bonding (that comes from a vague recollection of something I may have read). And the completed product:[/size]
Winglets installed with mural of the fall colors painted on the roof. Just kidding about the mural - nice reflection...
Old Oct 24, 2019 | 10:15 PM
Clutch Wotan's Avatar
Clutch Wotan
waiting for those
Old Oct 25, 2019 | 05:18 AM
Eddie07S's Avatar
Eddie07S
Originally Posted by Clutch Wotan
waiting for those
Who makes those?
Old Nov 10, 2019 | 02:13 PM
robby71's Avatar
robby71
Originally Posted by Eddie07S
Who makes those?
Maxton design - https://www.maxtondesign.co.uk/body-...refacelift-f56
Old Nov 10, 2019 | 04:38 PM
Eddie07S's Avatar
Eddie07S
I just noticed that those are for a different rear spoiler than what my JCW has...
Interesting, though.
Old Nov 11, 2019 | 09:15 AM
robby71's Avatar
robby71
Looks like the aero rear spoiler as fitted with the JCW bodykit
Old Jul 6, 2020 | 09:16 PM
Robert Marquez's Avatar
Robert Marquez
Where are you located exactly? I'm in PHX AZ and I'm Willing to drive down 350.00.
