JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
R52 JCW sway bar and x-brace question
Old 03-27-2017, 11:19 PM
Chiro444's Avatar
Chiro444
Chiro444 is offline
I'm thinking of getting an X-Brace so if anyone can let me know their experience that would be great. Also, does my JCW come with bigger sway bars or are people upgrading them? Thanks in advance.
Old 03-28-2017, 09:09 AM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
Is your car lowered? I like the x-brace, but have bottomed out a couple of times and my car isn't super low. The cat might also be hitting the x-brace under heavy acceleration making the car roar/vibrate like crazy, but I haven't been able to get a good look under the car yet to verify.
Not positive on the swaybars, but I think they are the same as what comes on the S. A lot of people go with solid 22mm bars or the hollow Hotchkis 25.5 bar.
Old 03-28-2017, 09:44 AM
Chiro444's Avatar
Chiro444
Chiro444 is offline
It has the stock suspension. I don't plan on lowering it.
Old 03-28-2017, 10:48 AM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
Bottoming out probably won't be an issue at stock height. Also, since there are different braces out there, the one I was referring to is made by TSW/Way Motor Works.
Old 03-29-2017, 04:27 AM
JackMac's Avatar
JackMac
JackMac is offline
Had the TSW/WMW brace on my R55 and you definitely notice the improvement. Sold the R55 and then sold the brace to a 2nd gen convertible owner. He has thanked me repeatedly on how much it improved chassis rigidity and handling on his car.
My R55 had stock Sport suspension and his R57 has stock sprigs with Koni sport struts. Both cars will bottom out the brace over high speed bumps. Just go slow over them and you should be fine. I would not use this brace on a lowered car.
Old 03-29-2017, 08:30 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
The sway bar on the JCW R52 and non JCW is the same.
The sway bar is by far the biggest bang for the buck mod on the suspension and always our first recommendation
https://www.waymotorworks.com/wmw-rear-sway-bar.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 03-29-2017, 08:37 PM
Chiro444's Avatar
Chiro444
Chiro444 is offline
Thanks for the info. How hard is it to install the sway bar and x-brace?
Old 03-29-2017, 08:58 PM
WayMotorWorks
Vendor
X brace will take longer to jack up the car than to install.
The sway bar. I can install in about 20min. So for someone doing it at home I would say budget 2hrs as it slows you down being on the floor.
