JCW JCW Pro vs AWE Touring Exhaust - Help Me Choose
Old Oct 26, 2016 | 08:39 PM
  #76
NellyRod's Avatar
NellyRod
Originally Posted by vetsvette
I'm considering swapping out my JCW Pro exhaust and replacing it with the track version of the AWE system. I'm not unhappy with the JCW because it has worked flawlessly since installing in January. I did have a problem with the flap closing on me at the Dragon a couple weeks ago, but after it failed completely I changed the battery in the remote and it solved the problem. I forgot to keep a spare battery (2032) in the car. The main reason I'm considering it is for the esthetics. I think the black tips would look better with the way I have my car blacked out. I refuse to spend the ridiculous amount of money they want for the OEM CF tips.
Have you considered keeping your JCW Pro exhaust and just replacing the tips? Unless you're also switching exhausts for the sound, buying black tips would be much cheaper. Lots of options out there too.
Old Oct 26, 2016 | 10:25 PM
  #77
rmcintos's Avatar
rmcintos
The tips on the JCW remove with a set screw. There's endless black tips that will fit the pipe diameter that are not OEM Mini. Check the diameter and search online or go visit a high end muffler shop.
Old Oct 27, 2016 | 08:04 AM
  #78
vetsvette's Avatar
vetsvette
Moderator
Anyone know the diameter of the JCW Pro exhaust outlets? Not the tips, but the actual pipe diameter. Due to physical limitations I can't get under the car to remove a tip and measure it. I found a set of tips that look okay on the ECS web site, but their sales guy couldn't tell me if they would fit.
Old Oct 27, 2016 | 08:11 AM
  #79
KYDan's Avatar
KYDan
Whitey, Flo mini service should be able to tell you or G3.
Old Oct 27, 2016 | 09:28 AM
  #80
rmcintos's Avatar
rmcintos
I'm 99% certain it's 2.75".
Old Oct 27, 2016 | 02:46 PM
  #81
mattkosem's Avatar
mattkosem
Yeah, I believe the piping is 70mm (2.756").
--Matt
Old Oct 27, 2016 | 02:56 PM
  #82
vetsvette's Avatar
vetsvette
Moderator
Good idea Dan, but no joy at either place.
--Matt
Thanks Matt. But, I think I had better wait until I can get it on a lift and pull one of the tips off and measure the pipe before spending another $150. Shouldn't have a problem selling the JCW tips at least.
Josh/AWE
Mar 21, 2016 12:35 PM
808R53
Detailing 101
Mar 18, 2016 04:49 AM
